Equilibrium position in bungee jump oscillation
7 replies · 6K views
mrcotton
The diagram show a student before and after she makes a bungee
jump from a high bridge above a river. One end of the bungee cord, which is of
unstretched length 25 m, is fixed to the top of a railing on the bridge. The other end of
the cord is attached to the waist of the student, whose mass is 58 kg. After she jumps,
the bungee cord goes into tension at point P. She comes to rest momentarily at point R
and then oscillates about point Q, which is a distance d below P.
The bungee cord behaves like a spring of spring constant 54Nm–1.
Calculate the distance d, from P to Q, assuming the cord obeys Hooke’s law.
What I can’t see is why this works for this distance when the cord stretches from P all the way down to R. Also only at P is the force just due to the weight (mg). I am assuming it has something to do with Q being the equilibrium position of the oscillation. Any pointers for my thought processes gratefully received.
I think I get it now. Q is the position that the girl on the rope would hang if stationary once all the energy has dissipated. Hence at Q mg=T and the extension of the bungee cord if a force of the girls weight were added would be from upstretched length to this new length
There is a further question that although I can apply the formulas I still struggle to see why this works.
Use your answers from parts (a) and (b)(i) to show that the amplitude A, which is the
distance from Q to R, is about 25 m.
Why can we use these values? Is it simply that we can say that on return to the point P after the first oscillation she will arrive there with the same velocity as she had when she was originally fell to P through the 25m distance. The speed at P being calculated from KE=GPE (v=sqrt(2gh). Then from conservation of energy if we ignore any dissipation of the energy the girl will bounce back up and be at the same speed at P again when she returns to this point moving vertically upwards?
OK the simple harmonic oscillation of a mass on a spring is a little more tricky than some, but still accessible to high school physics.
Remember the definition of SHM?
The motion such that there is always a restoring force and consequent acceleration directed towards a fixed point and proportional to the distance from it.
So consider your jumper.
Starting from the end of the bungee slack, (your point P) she is moving under the effect of two accelerations. Gravity and the bungee.
Initially gravity is greater than that provided by the bungee, but as the bungee stretches its restoring force increases until the point Q where it is exactly equal to that of gravity.
mg = ke where e = PQ
This is your first equation.
Note that from P to Q the acceleration and restoring force is directed downwards towards Q.
At Q the jumper has achieved some velocity vq and thereofre keeps going, still under the influence of gravity and the bungee tension.
However the tension continues to increase as the bungee stretches further and the tension is now greater than gravity and opposing it. Thus the resultant is still directed towards Q, as required by our SHM definition.
Measuring distance vertically from Q as y with downwards positive we find for some point B, y below Q.
extension of bungee = y+e and the tension = k(y+e)
Thus resultant = mg-k(y+e) = mg - ky - ke = -ky since ke=mg
Hence mg = -ky
and
acceleration = -k/my = -ω2y, where ω2 = k/m
So we have proved SHM about Q and can use the SHM formule
Period = 2∏/ω = 2∏√(m/k)
Also since mg=ke
Period = 2∏√(e/g)
Does this help?
Thank you so much, this makes a great amount of sense to me.
Glad it helped.
Would you like to consider an energy balance for the system?
This is slightly more complicated since there are several different energies involved. Can you spot them?
I would love to consider the energy balance of the system.
gravitational potential energy determined by the distance between P and R, however the GPE in the fall through the distance of 25m to get to P was used to calculate the speed at P.
elastic energy this is zero at P and increases until maximum at R then decrease as she returns back up to P.
and kinetic energy which must decreas from P to R as the speed decreases and the KE turns to the elastic potential energy. is it also true to say while descending from P to R the GPE is decreasing and turning into KE and then as she moves upwards from R back to P the KE and elastic turn into GPE all GPE at the maximum height.
This question came from an AQA past paper
http://store.aqa.org.uk/qual/gce/pdf/AQA-PHYA4-2-W-QP-JAN12.PDF
I really appreciate the help and I suppose I should also think about the direction and magnitude of the acceleration.
Aint physics brilliant!
The total gravitational potential energy available to the system is
The mass times the total fall from the railing to R (times g).
This is distributed into the vibrating system as
(1)strain energy in the bungee, (potential energy)
(2)kinetic energy of the person
(3)gravitational (potential) energy of the person.
If you take R as a zero point for energy purposes you can see that at R (2) and (3) are zero and at P (2) is zero.
