Solve Equilibrium Problem with Ammonium Phosphate
  • Thread starter Thread starter Grove1996
    Equilibrium
The discussion centers on determining the original amount and molarity of ammonium phosphate in a water sample, where ammonium levels are at 407.14 mg/L and phosphate at 9.42 mg/L. The user notes that the contaminant levels are 200% higher than normal and expresses confusion about using an ICE table due to the lack of initial concentration data. They have already conducted stoichiometric calculations but found discrepancies in the expected 3:1 ratio of ammonium to phosphate. The thread seeks guidance on how to calculate the original amount of ammonium phosphate and its molarity given the probe results. Clarification on the identification of ammonium phosphate is also requested to enhance understanding of the analytical process.
Grove1996
Problem:
I've been working on my assignment and the purpose of it is to determine the concentration of a contaminant present in a sample of water. I've discovered the contaminant is ammonium phosphate with the levels of each being 200% higher than normal water. I obtained these results using an ion-selective electrode and a colorimeter.
Probe Results:
Ammonium: 407.14 mg/L
Phosphate: 9.42 mg/L
I have to determine the amount of ammonium phosphate originally put into the sample of water, and its concentration (molarity). Usually I would do an "ICE" table but I don't know how much ammonium phosphate has originally been put in. I've done the stoichometry and determined that the 3:1 ratio between ammonium and phosphate does not exist (as the probe results suggest). Regardless, I have to determine the amount originally put in (preferably in grams) and the molarity of the solution.
I have no idea where to start, as I said before I would usually do an ICE table but that will not work in this case.
TLDR:
Probe readings show a total of approximately 407 mg/L of ammonium and 9.5 mg/L of phosphate. What process would I do in order to determine the original amount put in, and the molarity of the concentration.
Any help would be much appreciated.
how did you come to the conclusion that it is ammonium phosphate? Not challenging you, but your answer my help me understand your procedure better and potentially help you.
