Equilibrium Statistics -- Euler summation formula
15 replies · 2K views · last reply
In the calculation in high temperatures of ##Z_{rot} = (\sum_{j=0}^\infty (2j+1)\exp{j(j+1)\theta_{rot}/T})^N##; they use Euler summation formula:
$$\sum_{n=0}^\infty f(n) = \int_0^\infty f(x)dx+\frac{1}{2}f(0)-\frac{1}{12}f'(0)+\frac{1}{720}f^{(3)}(0)+\ldots$$
for ##f(x) = (2x+1)\exp{x(x+1)\theta_{rot}/T}##.
Now they get that: ##Z_{rot} = \bigg(T/\theta_{rot}+1/3+\theta_{rot}/(15T)+\ldots \bigg)^N##.
Now as for the third term I did the calculation and I get a minus sign, i.e. I believe it should be: ##-\theta_{rot}/(15T)## instead of ##+\theta_{rot}/(15T)##.
I get that the factor that multiplies ##\theta_{rot}/T## is ##12/720-1/12##.
Am I right or wrong?
Should the argument of the exponential function in ##Z_{rot}## and ##f(x)## have an overall negative sign? If not, I don't see how ##\int_0^\infty f(x) dx## could converge.
@TSny You are correct there should be a minus sign in the argument of the exponential, but in the Solution Manual it doesn't appear.
But in that case I think it should be -1/3 and not +1/3.
Please either use parentheses or ##e^{a}## instead of ##\exp(a)##. From what you wrote it is impossible to tell whether you want to compute
##\sum (2j+1) e^{j(j+1)} \theta/T## or ##\sum (2j+1) e^{j(j+1) \theta}/T## or ##\sum (2j+1) e^{j(j+1) \theta/T}##. Using "exp" these would be ##\sum (2j+1) \exp(j(j+1))\, \theta/T## or ##\sum (2j+1) \exp((j(j+1) \theta) /T## or ##\sum (2j+1) \exp((j(j+1) \theta/T)##. Using a "solidus" fraction ##\frac a b## would be even better"
$$\sum (2j+1) \frac{\exp(j(j+1)) \theta}{T}$$ or $$ \sum (2j+1) \frac{\exp(j(j+1) \theta)}{T}$$ or $$ \sum (2j+1) \exp \left( \frac{j(j+1) \theta}{T} \right)$$
And, of course, there is the issue of the missing "-" sign.
Also: does the Euler summation formula really go from ##f^{\prime}(0)## to ##f^{(3)}(0)##, skipping over ##f^{\prime \prime}(0)## altogether?
It should be: $$\sum (2j+1)\exp{\bigg(\frac{j(j+1)\theta_{rot}}{T}\bigg)}$$
Shouldn't that have a "-" sign in the ##\exp(\cdots)##? If not, you have a divergent series (unless ##\theta_{rot}/T < 0##).
No, a minus sign is indeed missing in the SM; and as far as I can tell ##\theta_{rot}/T>0##, as I wrote this approximation(?) is used for high temperatures, i.e ##T \gg \theta_{rot} ##.
BTW, you can find this SM scanned in the net; it's in the solution of problem 2.8 in the book by Bergersen's and Plischke's.
I get +1/3. It comes from a combination of +1/2 and -1/6. The +1/2 is from (1/2)f(0) and the -1/6 is from -(1/12)f'(0).
@TSny ok I agree it doesn't get changed.
In which case it's indeed ##+1/15 (\theta_{rot}/T)## and not ##-1/15 (\theta_{rot}/T)##, and what's wrong in the book is the missing sign in the exponential, am I correct?
Yes, I think so.
@TSny , @Ray Vickson after correcting the minus sign in the exponential; I have yet another minus sign problem which I want to correct or ask for your corroboration:
They write in the SM that:
$$E = \frac{\partial}{\partial \beta} \ln Z_{rot} = Nk_B T \frac{1-\frac{\theta_{rot}^2}{15T^2}+\ldots}{1+1/3 \frac{\theta_{rot}}{T}+\frac{\theta_{rot}^2}{15T^2}+\ldots}$$
But in the numerator I get that it should be: ##-1+\frac{\theta_{rot}^2}{15T^2}+\ldots##; I believe this expression for ##E## with the derivative is the definition of the internal energy, so I guess again a minus sign is missing here, am I correct?
TSny said:
Yes, a minus sign is missing in the expression for ##E##.
https://en.wikipedia.org/wiki/Parti...s)#Calculating_the_thermodynamic_total_energy
Thanks.
There's another thing that get me to scratch my hair metaphorically speaking;
They write that the series expansion of the above ##E## should be: ##E_{rot}=Nk_BT(1-\frac{\theta_{rot}}{3T}-\frac{2\theta_{rot}^2}{45T^2}+\ldots)##, but I get that instead of 45 it should be 15;
Where I have expanded:
$$1/(1+1/3 (\theta_{rot}/T)+(\theta_{rot}^2/(15T^2)+\ldots) = 1-\bigg[1/3 (\theta_{rot}/T)+(\theta_{rot}^2/(15T^2)+\ldots\bigg]$$
Have they got it wrong, yet again?
:-D
I haven't checked their answer, but you will need to go one order higher in your expansion of the denominator to get all of the ##\theta_{rot}^2/T^2## contributions.
I agree I forgot ##\bigg[ 1/3 \theta/T + \theta^2/(15T^2) +\ldots\bigg]^2##.
I get with this that the factor that multiplies ##\theta^2/T^2## is ##-2/15+1/9 = (-6+5)/45=-1/45##, is this correct?
Yes, I think that's right even though it doesn't agree with their factor of ##-2/45## as given in post #13.
