Gerenuk
- 1,027
- 5
Why is it that to derive general relativity you use the equivalence principle on gravity and not electromagnetism for example?
The discussion clarifies why the equivalence principle is applicable to gravity but not to electromagnetism in the context of general relativity. It establishes that gravitational mass and inertial mass are equivalent, allowing for the equivalence of reference frames under gravitational influence. In contrast, electromagnetism can be detected through local experiments, making it unsuitable for the equivalence principle. The key distinction lies in the dependency of acceleration on mass for gravity versus charge-to-mass ratio for electromagnetism.
PREREQUISITESStudents of physics, researchers in theoretical physics, and anyone interested in the foundational principles of general relativity and the distinctions between gravitational and electromagnetic forces.
Because the equivalence principle would be obviously false if applied to electromagnetism instead of gravity.Gerenuk said:Why is it that to derive general relativity you use the equivalence principle on gravity and not electromagnetism for example?
I don't know what a "Becauso so." answer is, but the "force" of electromagnetism isn't equivalent to a pseudoforce in accelerated reference frames the way gravitational "force" is.Gerenuk said:That's a "Becauso so." answer
Electromagnetism is a force and acceleration exhibits a force. So at least from the basic ideas that I heard it doesn't make a difference.
I think you've more or less worked this out now. In Newtonian terminology, the "acceleration due to gravity" of a particle does not depend on the particle's mass (or any other property of the particle). The "acceleration due to electromagnetism" depends on the particle's charge-to-mass ratio.Gerenuk said:Why is it that to derive general relativity you use the equivalence principle on gravity and not electromagnetism for example?
