Equivalent definitions of tensor field
cianfa72
TL;DR
About the equivalence of two different definitions of tensor field
As far as I know, there are two definitions of tensor field on a differential manifold ##M##. Just to fix ideas consider the two-times covariant tensor field ##T_{ab}## on it.
First definition: take the tensor product ##T_p^{*}M \otimes T_p^{*}M## as the fiber over the point ##p \in M## and define/build the fiber bundle over ##M##. Then ##T_{ab}## is a smooth section of such tensor product bundle on ##M##.
Second definition: given the tangent and cotangent bundles over ##M##, then ##T_{ab}## is a ##C^{\infty}##-multilinear map $$T_{ab} : \Gamma(T^{*}M) \times \Gamma(T^{*}M) \to C^{\infty}(M)$$ where ##\Gamma(T^{*}M)## is the ##C^{\infty}(M)##-module of the set of smooth sections of ##T^{*}M##.
Are the two definitions actually equivalent ?
Why wouldn't they be?
Can you formally prove it ?
cianfa72 said:
TL;DR: About the equivalence of two different definitions of tensor field
The second doesn't look correct. It should be a multilinear function of sections of the tangent space, not the cotangent space.
It's helpful to just look at a vector space since fields over a bundle don't really add that much.
But for a vector space ##V## over the field ##\mathbb R##, ##V^* \otimes V^* \cong L(V, V) \rightarrow \mathbb R## where ## L(V, V) \rightarrow \mathbb R## is the space of bilinear functions on ##V##.
Oops yes, a twice covariant tensor field eats two vector fields :-)
Yes, definitely.
Look now at the writing ##T^*M \otimes T^*M##. What does it refer to ?
I believe it is just a notation for the fiberwise tensor product of cotangent bundles. Indeed a (vector) fiber bundle doesn't carry any vector space structure, hence the symbol of tensor product between them is meaningless. So it basically means taking the bundle over ##M## of the fiberwise tensor product ##T^*_pM \otimes T^*_pM## for any ##p \in M##.
Yes, definitely.
Yes. In Lee's book, he defines a smooth functor with which you can lift constructions on vector spaces to vector bundles. https://en.wikipedia.org/wiki/Smooth_functor
  • · Replies 55 ·
10K
  • · Replies 36 ·
