Error equation for the balmer series
  • Thread starter Thread starter wahaj
    Error Series
The discussion focuses on calculating the error in the wavelength (λ) determined by the Bohr model's Balmer series. The participant uses the equation \(\frac{1}{\lambda} = R \left(\frac{1}{n^2_f} - \frac{1}{n^2_i}\right)\), where R is the Rydberg constant with an error of ±1 in the last digit. The confusion arises from the presence of λ in the error equation, leading to a need for clarification on how to isolate λ and perform error analysis correctly. The final equation for error in λ is expressed as δλ = λ²(1/K)δR, where K represents the difference in the squared terms.
  • Understanding of the Bohr model and the Balmer series
  • Familiarity with the Rydberg constant and its significance in spectral lines
  • Knowledge of error propagation techniques in physics
  • Ability to manipulate algebraic equations involving variables and constants
  • Study the derivation of the Rydberg formula for hydrogen spectral lines
  • Learn about error propagation methods in experimental physics
  • Explore the concept of differential calculus as applied to physical equations
  • Investigate the significance of significant figures in measurement and error analysis
Students in physics, particularly those studying quantum mechanics and atomic structure, as well as anyone involved in experimental physics and error analysis methodologies.
wahaj
I have to find the error in λ determined by the Bohr model/Balmer series. I am a bit confused with this so I'd like someone to double check my work. I don't know the exact name of this method but basically all you do is take the differential of all the values which have an error to find the error of the determined value.
\frac{1}{\lambda} = R (\frac{1}{n^2_f} - \frac{1}{n^2_i} )
nf and ni are discreet values so they have no error in them
R is the Rydberg constant and has an error of +-1 in the last digit so
R = (1.097 +- 1 ) * 107 m-1
\frac{\delta \lambda}{\lambda^2} = \delta R (\frac{1}{n^2_f} - \frac{1}{n^2_i} )
\delta \lambda = \lambda^2 (\frac{1}{n^2_f} - \frac{1}{n^2_i} ) \delta R
The reason I am confused with this is that I am trying to find the error in λ but λ shows up on the right hand side of my error equation. Also did I get the error in R in the right decimal place?
First: replace everything in brackets with 1/K and solve for lambda.
Now find the error on lambda - should clear up your confusion.
that works thanks
So is the equation supposed to look like as follows: δλ=λ2(1/K)δR? I am so confused.
@dab353: welcome to PF;
Take it step-by-step.
Start with the full equation.
Substitute the 1/K in for the brackets... that's just to make it clear.
Solve that equation for lambda.
Do the error analysis like normal.
17K
  • · Replies 23 ·
