Error in defined expression for Fresnel equation in matlab ( please )?
9 replies · 4K views
error 401
error in defined expression for Fresnel equation in MATLAB (urgent please )??
hi
i have code for plotting Fresnel equation but there's something i didn't understand it and gives
error >>(((
plotopt - plotting option (type 'R' for plotting reflectivity,
% 'A' for absorptivity or 'RA' for both)
any body can explain what should i do .. and how can i define (plotopt ) ? thanks in advance !
the total code ((
thetadeg = (0:0.1:90);
theta = thetadeg*pi/180;
[a,b,c] = intrc(n1,n2,k2,theta);
if nargin<4 || isempty(plotopt)
fprintf('No plotting option specified. Type \''help fresnelplot\'' for further details.\n');
return;
end;
if nargin==4
if ischar(plotopt)
switch plotopt
case {'R','r'}
plot(thetadeg,a,thetadeg,b,thetadeg,c)
legend('Rs','Rp','R','Location','northwest');
xlabel('Angle of incidence \theta');
ylabel('Reflectivity');
case {'A','a'}
plot(thetadeg,1-a,thetadeg,1-b,thetadeg,1-c)
legend('As','Ap','A','Location','northwest');
ylabel('Absorptivity');
case {'RA','ra','AR','ar'}
subplot(2,1,1)
subplot(2,1,2)
otherwise
fprintf('%s is not a valid option. Type \''help fresnelplot\'' for further details.\n',plotopt);
end;
else fprintf('Option must be a string. Type \''help fresnelplot\'' for further details.\n');
end;
end;
It looks to me like the above is the body of a function with parameters for plotopt and nargin.
Your code is using these values without ever having set them to known values.
i am using MATLAB 2009 . and gives the error (( ? Undefined function or variable 'plotopt'.))...
That's what I'm saying. The code you show refers to plotopt (and nargin) and MATLAB doesn't know what these are.
In post 1, you wrote "the total code". What you show is NOT the total code - it's missing a definition of plotopt.
Where did you get this code?
Your plotop is input from the user.
or 'RA' for both
how can i use this in code ?
The link you gave was to an "m file", a file that defines a function that is called by other MATLAB code.
Look in the MATLAB documentation for how to call a function that is defined in another file.
The part that you left out in your post is shown below.
Code:
function fresnelplot(n1,n2,k2,plotopt)
% fresnelplot(n1,n2,k2,plotopt)
% plots the Fresnel reflectivities and/or absorptivities (s-pol, p-pol
% and circ.) for light incident from a dielectric medium with
% refractive index n1 on an opaque absorbing medium with complex refractive
% index n2+i*k2.
% Input:  n1      - refractive index (medium 1)
%         n2      - refractive index (medium 2)
%         k2      - extinction coefficient (medium 2)
%         plotopt - plotting option (type 'R' for plotting reflectivity,
% Output: plots of reflectivities and/or absorptivities
% Last updated: 2011-10-26 (David Bergström)
he says >>
i know about m-file already !. but there's no function called (plotting option ) .so the problem is how can i use this in matlab. what is the function should i use for ?
on other hand there's no m-file attached , and i don't know the code for make a new one !
error 401 said:
he says >>
plotopt is not a function. It is a parameter in the fresnelplot function.
Open the link you posted (http://www.mysimlabs.com/matlab/auxiliary/fresnelplot.m ).
Copy the code at this link into any editor (Notepad or whatever).
Save to a file named fresnelplot.m in your MATLAB working directory.
Your MATLAB code that uses the fresnelplot function should look something like this:
Code:
n1 = input("Enter refractive index for medium 1")
n2 = input("Enter refractive index for medium 2")
k2 = input("Enter extinction coefficient for medium 2")
plotopt = input("Enter plot option")
fresnelplot(n1, n2, k2, plot)
For the plot option, you can enter R, A, RA, or AR.
