Mathematica Solving Mathematica Error: NIntegrate::ncvb
The discussion revolves around resolving the Mathematica error NIntegrate::ncvb, which indicates failure to converge to the desired accuracy during numerical integration. The user experiences this issue particularly when the lower limit of integration approaches zero, suggesting that the integral may be improperly defined at that point. Suggestions include testing individual iterations of the loop to identify specific values causing the error, adjusting the precision goal, or increasing the number of recursive iterations allowed. The conversation also highlights the importance of ensuring that the mathematical formulation matches the code implementation, as discrepancies between the two can lead to integration issues. Ultimately, refining the integral's limits and parameters is crucial for achieving accurate numerical evaluations.
EngWiPy
Hello,
I have the following code in Mathematica, and it gives the following error:
Code:
NIntegrate::ncvb: NIntegrate failed to converge to prescribed accuracy after 12 recursive bisections in x near {x} = {0.000156769}. NIntegrate obtained 0.21447008480474927` and 5.637666621985554`*^-13 for the integral and error estimates. >>
How to solve this error?
Code:
yp = 10^(5/10);
GSS = 10;
For[yQdB = -10, yQdB <= 10, yQdB++;
yQ = 10^(yQdB/10);
Print[yQ];
A1 = NIntegrate[
   1/x^2*Exp[(GSS*(x + GSS*yQ))/(x*yp) - x]*
    ExpIntegralE[1, (GSS*(x + GSS*yQ))/(x*yp)], {x, LL, Infinity},
   PrecisionGoal -> 12, MaxRecursion -> 12];
You have a loop, so a natural step to narrow down the error would be to test individual iterations of the loop. Does every value of yQdB produce the problem? Did you try a lower precision goal or a deeper recursion? Note that the precision is close to the target.
Likes EngWiPy
No actually it's not for every value of yQdB. What do you mean by "Note that the precision is close to the target."?
That is a relative uncertainty of about 3*10-12.
So, do I need to increase the precision?
Another thing, which is that the lower limit of the integral is theoretically zero. However, since the program doesn't compute it by saying that the integral has evaluated to overflow, indeterminate, or infinity, I replaced it but ##LL=10^{-5}##. However, when I compare the results with Monte-Carlo simulations (the above formula is the numerical result), there is some discrepancy. How to make the numerical evaluation as accurate as possible?
The opposite. Mathematica is unable to require the precision you ask for with the number of iterations you allow. Allow more iterations or reduce the precision you ask for and it should work.
Why do you think the problem is with Mathematica?
Fair point. I'm not sure if the problem is with Mathematica. I posed a question in the calculus forums to double check if there is something fundamentally wrong with the math, but I haven't gotten a conclusive answer.
Well, we can't tell. You wrote down an integral. Mathematica evaluates it. Is this the right integral you want to calculate? No idea.
Also it helps to give the integral you are trying to evaluate in latex with proper symbols.
That makes it easier to check for typos in the code (don't ask me how many times I made that kind of mistake :S) or whether there is some mathematical reason for the error message.
I think the mathematical derivations were accurate. I'm not sure about the limits though. The integral is the following
\int_0^{\infty}\frac{1}{x^2}\exp\left(\frac{A}{x}-x\right)E_1\left(B+\frac{A}{x}\right)\,dx
More details are found here.
You mentioned in post #3 that the error doesn't happen for every yQdB, could you narrow it down some more?
With these kinds of expressions you sometimes overlook undefined cases.
Edit;
I also think your expression in mathematica has ##A=A(x)## meaning you have an extra subtlety.
Really? Do you mean I should use square brackets all the time in Mathematica?
I have rewritten the expression in your code to make it more clear what happens.
\frac{1}{x^2}\exp\left[ \frac{G_{SS}\left(x+G_{SS} \cdot y_Q\right)}{xy_p}-x\right]
E_1\left[\frac{G_{SS}\left(x+G_{SS}y_Q\right)}{xy_p}\right]=\frac{1}{x^2}\exp\left[ \frac{G_{SS}}{y_p}+\frac{G_{SS}^2 \cdot y_Q}{xy_p}-x\right]E_1\left[\frac{G_{SS}}{y_p}+\frac{G_{SS}^2y_Q}{y_px}\right]$$
If you now define ##A=\frac{G_{SS}^2y_Q}{y_p}##, ##B=\frac{G_{SS}}{y_p}## and ##C=\frac{G_{SS}}{y_p}## this results in
E_1\left[\frac{G_{SS}\left(x+G_{SS}y_Q\right)}{xy_p}\right] = \frac{1}{x^2}\exp\left[C +\frac{A}{y_p}-x\right]E_1\left[\frac{G_{SS}}{y_p}+\frac{A}{x}\right]
So either you have different A's as you can get the right form in the exponential by setting ##A^\prime(x)=\frac{G_{SS}\left(x+G_{SS} \cdot y_Q\right)}{y_p}## leading to
$$\frac{1}{x^2}\exp\left[\frac{A^\prime(x)}{x}-x\right]E_1\left[\frac{G_{SS}}{y_p}+\frac{A}{x}\right]$$
So you have to check that if really want this or the integral in post #11.
Edit;
I used square brackets and parentheses for clarity but these expressions are not code, I don't like reading the code directly most of the time as it can obscure things which seem obvious in retrospect.
Edit 2;
As Tom pointed out I made a mistake, it's now fixed
JorisL said:
I have rewritten the expression...
1x2exp&#x2061;[GSS(x+GSS&#x22C5;yQ)xyp&#x2212;x]E1[GSS(x+GSSyQ)xyp]=1x2exp&#x2061;[C+Ayp&#x2212;x]E1[GSSyp+Ax]" style="font-size: 106%; position: relative;" tabindex="0" class="mjx-chtml MathJax_CHTML" id="MathJax-Element-8-Frame">1x2exp[C+Ayp−x]E1[GSSyp+Ax]
As you you Defined A, above, should the exp term in the rewrite have A/x rather than A/yp ?
EDIT: well, that didn't copy thru as intended!
You're absolutely right, thanks for pointing that out.
Best way to copy formulas is to use quote or reply since that copies the LaTeX codes.
Edit;
Edit 2;
Yes, you are right. But if you saw the Mathematica code, it's detailed. I used the constants A and B in the mathematical integral for convenience.
So my question is, does the variable A in the mathematical integral really represent a constant?
Because that is not reflected in your mathematica code as I've shown.
Is there a unique value of yQdB for which the evaluation fails? Or are there several values that cause trouble?
@Tom.G
Copying equations works best through reply or quote. They are typeset using LaTeX through MathJax.
You seem to have copied the html-code representing the equation which is quite odd.
In the Mathematica code there is no A. As I said, I used A and B for mathematical convenience, and your expression is more accurate mathematically. But again Mathematica code is still correct as I wrote it detailed; I didn't write it in terms of A and B.
The problem occurs at almost all values of yQdB where the lower limit of the integral is 0. But when I use a lower limit that is close to zero (like in the following code), I will have the error occurring at certain values.
Code:
yp = 10^(5/10);
GSS = 1;
Cons = 10^-7;For[yQdB = -10, yQdB <= 15, yQdB++;
yQ = 10^(yQdB/10);
A1 = 0.5*((GSS^2)*yQ )/yp*
   NIntegrate[
     ExpIntegralE[1, (GSS*(x + GSS*yQ))/(x*yp)], {x, Cons, Infinity},
    PrecisionGoal -> 5, MaxRecursion -> 12];
Print[A1]
The above code is working fine. But when I change GSS to 100, the error appears again, but at certain values. I'm not sure why?
S_David said:
yp = 10^(5/10);
Does Mathematica evaluate this as the square root of 10? Many programming languages would evaluate 5/10 as 0, using integer division rather than floating point division, thereby setting yp to 1.
Out of curiosity, why are you raising 10 to the 5/10 power?
Even if you don't have it explicitly, I showed in post #14 that you're mathematica code doesn't compute an integral of the form you gave.
Try putting this in your loop
Code:
Print["A1 = ", 0.5*((GSS^2)*yQ)/yp, "*NIntegrate[  1/x^2*Exp[ ( ", GSS, "*(x +", GSS*yQ, "))/(x*", yp, ") - x]* ExpIntegralE[1, (", GSS, "*(x + ", GSS*yQ, "))/(x*", yp, ")]"]
It will show you which integral is being evaluated (without the domain and options as they don't change).
That way you'll know what the exact integral is that doesn't work.
Because usually we choose the value of yp in dB, while in computation we use it in linear scale. So, yp in dB is 5 while in linear scale it's 10^(5/10).
Code:
In mathematical form, the integrad is
\frac{1}{x^2}\exp\left[ \frac{G_{SS}\left(x+G_{SS} \cdot y_Q\right)}{xy_p}-x\right]<br /> E_1\left[\frac{G_{SS}\left(x+G_{SS}y_Q\right)}{xy_p}\right]<br />
In Mathematica it's
Code:
They both look the same to me! Am I missing something here?
I copied your line, but didn't know how to use, or what I'm looking for. :oldconfused:
If you compare the two you see that in the code ##B=0## while ##A## explicitly contains ##x## (it's linear in x).
Meaning it isn't the same integral. I'm sure your code is right but the mathematical discussion in the other thread isn't really relevant.
S_David said:
<snip>
You put it inside your For loop above the NIntegrate-function.
It will print your command without executing it i.e. show you what the integrand looks like.
But again you referred to the integral which was written in terms of A and B. I just wrote it this way here to make it easier for the reader to read. The integral as it's in post #23 is the same as the integral in Mathematica. This is the integral in my calculations. Not the one I wrote here which you just quoted.
Your line gave me this for the first value of yQdB
Code:
A1 = 199.054*NIntegrate[  1/x^2*Exp[ ( 100*(x +10 10^(1/10)))/(x*Sqrt[10]) - x]* ExpIntegralE[1, (100*(x + 10 10^(1/10)))/(x*Sqrt[10])]
All I'm saying is that they aren't the same. And you gave that expression when asked to reproduce the integral you where trying to evaluate.
This is confusing (at best).
Apparently I made a mistake when copying, it isn't important though. (The constant factor before NIntegrate shouldn't be there according to post #1, it shows up in #19 though)
Am I correct with saying ##GSS=100## and ##yQdB=1## since that would mean there's a problem with " 10 10^(1/10)" in the output.
I cannot reproduce the prefactor either (everything is off by a factor of 10)
Edit;
Can you post the exact code you're using right now once more?
That way I can safely assume the same constants are used and compare output.
Edit;
I agree, it's confusing. I made a mistake. The code I'm using right now, including your line is
Code:
yp = 10^(5/10);
GSS = 100;
yQ = 10^(yQdB/10);
   NIntegrate[
  "\[Times] NIntegrate[  1/x^2\[Times]Exp[ ( ", GSS, "\[Times](x +",
  GSS*yQ, "))/(x\[Times]", yp, ") - x]\[Times] ExpIntegralE[1, (",
  GSS, "\[Times](x + ", GSS*yQ, "))/(x\[Times]", yp, ")]"]
Ref Post #18:
Thanks, my bad. The confusion arose because the "PREVIEW..." button does not show the nicely formatted result; so I thought I'd try a different approach.
Next time I'll know.
Any hint?
I'll try to look at it tommorow, I recall getting "Null" results when I saved the results in a table.
13K
