What Is the Cost of Energy Loss in a Low Voltage Power Supply System?
  • Thread starter Thread starter alwaysdazed
    Power
The discussion focuses on calculating the energy loss in a low voltage power supply system delivering 19 MW at 120 V using 0.60 cm diameter copper wire. The user successfully determined the current to be 158 A using the formula P=IV. To find resistance, they need to use R=(ρ*L)/A, where L is set to 1 meter for the purpose of calculating cost per meter. The cost of energy loss is calculated based on the power loss per meter and the electricity cost of 8.5 cents/kWh.
  • Understanding of electrical power formulas (P=IV, P=I²R)
  • Knowledge of resistivity and its application in resistance calculations
  • Familiarity with cross-sectional area calculations for cylindrical wires
  • Basic principles of energy cost calculations
  • Learn about resistivity of copper and its impact on power loss
  • Research the implications of wire diameter on resistance and energy efficiency
  • Explore methods for optimizing low voltage power supply systems
  • Investigate the economic impact of energy loss in electrical systems
Electrical engineers, energy analysts, and students studying power systems who are interested in understanding energy loss in low voltage applications.
alwaysdazed
A small city requires about 19 MW of power. Suppose that instead of using high-voltage lines to supply the power, the power is delivered at 120 V .
Assuming a two-wire line of 0.60cm -diameter copper wire, estimate the cost of the energy lost to heat per hour per meter. Assume the cost of electricity is about 8.5 cents/kWh.
Cost = $ per hour per meter
P=IV
P=I^2*R
R=(rhoe*L)/A
I used P=IV to find the current (converting 19 MW to 19*10^3 to keep it in kW for the answer) and found I=158 A .. then when I go to find the resistance I figure to use pi*r^2 as area than multiply the whole thing by two for the two wires but I do not understand what to use for L because they provide no length after i find R i intend to plug it into the equation P=I^2*R .. i am so lost!
Since they want cost per meter, you really just need R/L and P/L.
p.s. welcome to PF.
thanks but i do not understand what you are saying sorry :(
Okay, let's back up a little.
From your 1st post, you said you tried to calculate R, but need L in order to do that. What equation for R are you using, that has an L in it?
ohhh yeah that's what my problem is i am not given L .. i am trying to use R=(rho(resistivity)*L)/A
L being the length of the wire and A being the cross sectional area of the wire
Okay.
Since you need to calculate power and cost per meter, use L=1m.
okay so then i use l=1 to find the resistance and i take the current that i found usuing p=iv and plug both into P=I^2R .. once i find that P how do i incorporate finding time?
  • · Replies 20 ·
11K
