Estimating the value of an integral
  • Thread starter Thread starter tangibleLime
    Integral Value
The discussion focuses on estimating the value of an integral using the properties of upper and lower bounds. Initially, there was confusion about the notation used for M and m, which led to incorrect attempts at the solution. The correct approach involves identifying the maximum and minimum values of the function 5/(1+x^2) over the interval [0,1]. The maximum occurs at x=0 and the minimum at x=1, allowing for the proper application of the inequality. Ultimately, the integral value is estimated correctly by applying these bounds.
tangibleLime
It is known that if m[PLAIN]http://www.webassign.net/images/lteq.giff(x)[ATTACH=full]196966[/ATTACH]M for a[PLAIN]http://www.webassign.net/images/lteq.gifx[ATTACH=full]196967[/ATTACH]b, then the following property of integrals is true.
symimage.cgi?expr=%20m%28b-a%29%20%3C%3D%20int_a%5Eb%20f%28x%29dx%20%3C%3D%20M%28b-a%29%20.gif
Use this property to estimate the value of the given integral.
____________ <=
<= _____________
Honestly, I don't really know what it wants for a solution. I put in two numbers that satisfied the inequality, but it marked it wrong, so I assume it wants some sort of expression. The value of the integral itself is 5pi/4, but other than that I am at a complete loss for how to even begin.
Nevermind, I figured it out... I was overcomplicating it. I didn't realize they were using M and m as a function... I thought they were multiplying it. So m(1) <= 5/(1+1^2) = 5/2, and so-forth.
They were multiplying it. Over the interval [0,1], the function 5/(1+x2) attains a maximum at x=0 and a minimum at x=1, so you can use the values m=f(1) and M=f(0) in the inequality.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
