Ethanol Deception - Is It Really Better Than Gasoline?
  • Thread starter Thread starter Ivan Seeking
    Ethanol
100 replies · 17K views
I am running out of time and didn't spot the link that I used the other night, but what I am seeing during a quick search is even worse.
Right now, about 16 percent of the U.S. corn crop is going into ethanol production, but the fuel makes up less than one percent of U.S. demand for liquid fuels, once you take into account the amount of energy needed to produce the ethanol, Stephanopoulos said. Even if all U.S. corn went into ethanol production, there would only be enough for 4 to 5 percent of U.S. annual liquid fuel consumption...
http://www.physorg.com/news90166168.html
There was one paper talking about 3 parts in 10,000 gain, but I must not have understood the context.
The link I am looking for and forgot to save [either .edu or .gov] listed the net energy density as about 25 or 26,000 BTUs per gallon after processing [as a net measure of the gain]. So I will find that or a similar link, and will also link to a recent panel discussion on PBS in which opponents claim the gain is zero if the entire picture is considered. Again, this all applies to corn-ethanol.
These are more in line with my other reference.
http://www.usask.ca/agriculture/caedac/Ethanol/ethtable1.html
They show some optimistic estimates, but the real values for industry are much lower - listed as net gain of 38%. Also, some of these numbers seem inflated compared to other sources.
Chemistry news on Phys.org
This doesn't have anything to do with the amount of land area required to replace gasoline with ethanol. Your estimate of 2X the land area of the U.S. is clearly wrong.
Ah, I think I see your point - the gains by not refining petro? What is the basis for your assertion? I haven't had the chance to make my case, and you never addressed the energy needed for all petro.
How much refined product do we buy? Right now we are importing refined products because we don't have enough here, so this is not energy that we pay for with energy.
And I want to pursue this, but clearly it is impossible to convert to ethanol from corn.
Also, as long as there are opponents arguing that the net gain is zero, there is a possibility that no any amount of corn could replace petroleum.
Please see: A.E. Farrell et al., "Ethanol Can Contribute to Energy and Envoronmental Goals", Science, Vol. 311, p. 506-508, 27 January 2006 (www.sciencemag.org[/url]).[QUOTE=A.E. Farrell, et al.]The published results, adjusted for commensurate system boundaries, indicate that [b]with current production methods corn ethanol displaces petroleum use substantially[/b]; only 5 to 26% of the energy content is renewable. The rest is primarily natural gas and coal (Fig. 2)...[b]producing one MJ of ethanol requires far less petroleum than is required to produce one MJ of gasoline[/b] (Fig. 2).[/quote][url]http://rael.berkeley.edu/EBAMM/FarrellEthanolScience012706.pdf[/URL]
http://www.usask.ca/agriculture/caed...ethtable1.html
How much corn you could get if the entire US were devoted to corn growing is irrelevant. Only 3.6% of US land is devoted to growing corn (81.6 million acres out of 2,264 million acres). Corn wouldn't be a very suitable crop for many areas of the country, so you can't just expand how much land is devoted for corn (or sugar cane for that matter) - hence the pessimistic numbers Ivan quoted. With higher corn prices (which ethanol would drive), you'd expect the amount of land devoted to growing corn or sugar cane to increase (109 million acres were devoted to corn in 1931), but it will still be a small percentage of total land in the US.
On the other hand, corn production has increased from 24.5 bushels/acre in 1931 to 148.4 bushels/acre in 2005. Even though the amount of acreage devoted to growing corn has decreased, the total production is 5 times higher than it was in 1931, while the population is a little more than double what it was in 1931.
http://www.ncga.com/news/OurView/pdf/2006/FoodFuelCharts.pdf
http://www.ers.usda.gov/StateFacts/US.HTM
If you produced ethanol only engines in addition to gasoline engines, we'd still probably be a net importer of fuel products, but we'd be importing less and have a wider selection of sources.
If you had engines similar to the MIT design, you'd decrease overall gasoline use without forcing users to decide between 3 types of engines (gasoline, deisel, ethanol). You'd keep a lot of the standardization that makes gasoline easier to sell. I'm not sure how important that would be since deisel is a pretty viable fuel, even if not as popular as gasoline.
In other words, ethanol isn't the magical cure to US fuel woes, but it could make them a little less painful.
Ivan Seeking said:
Okay, I wasn't aware of the higher compression ratios possible, but since these cars are not available and the reality is what we actually have, ethanol probably offers no financial advantage.
And for anyone who want to do the calculation, when you see the 400 gallon per acre yields for corn, after the processing requirements, multiply by 0.3 [best case for corn] as the net gain. Others claim that the real multiplier is more like 0.1 or 0.2, and some even argue that the multiplier is 0.0 - that ethanol energy is just hidden petroleum energy and it is only competitive due to subsidies.
I'm not quoting this to argue the numbers. I want to point out that after the alcohol is taken out of corn there is a lot of useful product left. It cannot be dismissed. If we need products from corn to start with, or any other crop for that matter, then what is the problem with getting the alcohol out of it when it will be grown regardless?
I will be back later today or tonight. I wasn't ready with my links and need time to sort things out. I've been puting together a presentation for something else [related], and much of my information is in my notes at this point.
MeJennifer said:
If we go to CNN.com we can find the article http://www.cnn.com/2007/AUTOS/05/24/cr_mpg_survey/index.html" placed today on the CNN website.
Okay, that is the story referenced in yesterday's report. Apparently the news anchor had bad info as I think it was he who actually said that according to the CS study, ethanol was comparable to gasoline, when in fact their own report tells a different story, but they didn't show the entire report. It seems that what I saw was a leader story for this report. So it was the fault of CNN and CR got it right.
Aether said:
Please see: A.E. Farrell et al., "Ethanol Can Contribute to Energy and Envoronmental Goals", Science, Vol. 311, p. 506-508, 27 January 2006 (www.sciencemag.org[/url]).[url]http://rael.berkeley.edu/EBAMM/FarrellEthanolScience012706.pdf[/URL][/QUOTE]
I still need to take some time to review this - till now I have been trying to find a great link that I forgot to log and can't find. But for now, this gives an overview of the debate.
[quote]...The stickiest question about ethanol is this: Does making alcohol from grain or plant waste really create any new energy?
The answer, of course, depends upon whom you ask. The ethanol lobby claims there's a 30 percent net gain in BTUs from ethanol made from corn. Other boosters, including Woolsey, claim there are huge energy gains (as much as 700 percent) to be had by making ethanol from grass.
But the ethanol critics have shown that the industry calculations are bogus. David Pimentel, a professor of ecology at Cornell University who has been studying grain alcohol for 20 years, and Tad Patzek, an engineering professor at the University of California, Berkeley, co-wrote a recent report that estimates that making ethanol from corn requires 29 percent more fossil energy than the ethanol fuel itself actually contains.
The two scientists calculated all the fuel inputs for ethanol production—from the diesel fuel for the tractor planting the corn, to the fertilizer put in the field, to the energy needed at the processing plant—and found that ethanol is a net energy-loser. According to their calculations, ethanol contains about 76,000 BTUs per gallon, but producing that ethanol from corn takes about 98,000 BTUs. For comparison, a gallon of gasoline contains about 116,000 BTUs per gallon. But making that gallon of gas—from drilling the well, to transportation, through refining—requires around 22,000 BTUs.
In addition to their findings on corn, they determined that making ethanol from switch grass requires 50 percent more fossil energy than the ethanol yields, wood biomass 57 percent more, and sunflowers 118 percent more. The best yield comes from soybeans, but they, too, are a net loser, requiring 27 percent more fossil energy than the biodiesel fuel produced. In other words, more ethanol production will increase America's total energy consumption, not decrease it. (Pimentel has not taken money from the oil or refining industries. Patzek runs the UC Oil Consortium, which does research on oil and is funded by oil companies. His ethanol research is not funded by the oil or refining industries.)[continued][/quote]
[url]http://alt-e.blogspot.com/2005/07/alternative-fuel-ethanol-fuel.html[/url]
Also, sure, it is possible to divert the energy demand to other sources, but this does not make ethanol truly competitive as an alternative. It becomes more of an energy carrier rather than an energy source. So in this sense ethanol would be more like hydrogen, in which case we might as well just make hydrogen. And we don't need to load-up the grid driving alternative options. This is one point on which even Russ and I agree.
Also, BobG's quote
[quote]How much corn you could get if the entire US were devoted to corn growing is irrelevant. Only 3.6% of US land is devoted to growing corn [/quote]
Combined with an optimistic estimate given earlier
[quote]Right now, about 16 percent of the U.S. corn crop is going into ethanol production, but the fuel makes up less than one percent of U.S. demand for liquid fuels, once you take into account the amount of energy needed to produce the ethanol, Stephanopoulos said. Even if all U.S. corn went into ethanol production, there would only be enough for 4 to 5 percent of U.S. annual liquid fuel consumption...[/quote]
we come up with a demand of ~20 or 25 X 3.6% = 72% to 90% of the land area of the US, so already we are close to my statement of twice the land area without getting specific about where all of the petroleum energy goes, and at what efficiency. But it is true, when I figured this I was not assuming that we in effect cheat by diverting the energy of processing to other sources as this really doesn't solve the basic problem.
Oh yes, apparently that number of 3 parts in 10,000 gain [0.03%] was for cellulosic ethanol from corn, which I know nothing about at this point.
Also, note that the values will vary quite a bit from source to source, including the raw energy densities.
First, in spite of prior objections, I maintain that energy is a perfectly good way to compare fuels as long as the efficiency is known for each application. After all, in the end, sooner or later, we have to talk about the work done. This is ultimately what we have to compare. And the increased efficiency wrt ethanol in high compression engines does not apply to what we are actually driving, which was my point of reference. The CS/CNN report showed a 27% decrease in mileage in going from gasoline to ethanol, and if we take the ratio of the energy content of each as 125,000 and 76,000 BTUs per gallon respectively (76/125), we might expect about a 39% decrease, which isn't too bad as a ball park estimate given no other specifics. And of course we find significant differences in the raw energy estimates as well as differences in the fuel quality at the pump that could account for this, in addition to any efficiency variances between fuels. Not to mention that the test may have had a large margin of error.
Here are some more good links including:
Ethanol fuel from corn faulted as 'unsustainable subsidized food burning' in analysis by Cornell scientist
http://www.news.cornell.edu/releases/Aug01/corn-basedethanol.hrs.html
http://journeytoforever.org/ethanol_energy.html
Overall, we use about 100 quads [quadrillion BTUs] of energy each year from all sources, and in 1998 [easiest reference], 38.8% of this energy came from petroleum.
We can consider the typical efficiencies of diesel to include most petroleum energy [when taken with the estimates earlier for the ethanol needed for gasoline], and then consider how much ethanol we need to replace this. In fact we might just be generous and assume that ethanol would be as efficient as diesel as a starting point.
The total demand for refined products is listed here
http://tonto.eia.doe.gov/dnav/pet/pet_cons_psup_dc_nus_mbbl_a.htm
For 2005, I count about 3 thousand million barrels of fuel oil at 42 gallons per barrel, and assuming 139,000 BTUs per gallon, we get a total of 1.75E16 BTUs. Now, if we assume the same efficiencies for ethanol at [76,000 BTUs per gallon] as we get from the fuel oil, we get 2.3E11 gallons of ethanol, and at 30% yields we need 7.8E11 gallons, or about 1.7E9 acres of corn to replace diesel fuel and oil used for heat. This would be in addition to the ethanol needed for gasoline, so as you can see, we can easily get to absurdly large numbers and about twice the land area of the US at 2.2E9 acres. But again, this assumes that we don't steal energy from other sources to make the ethanol. And of course the potential error is fairly large, but we are working in units of nuclear bombs anyway, and we can get close enough for perspective. Also, we assumed the ethanol would be as efficient as diesel, and today it's not, so we might add as much as another 30% to our 1.7 billion acres. And lastly, I don't know of any large trucks that run on ethanol.
Now should we consider aviation?
When I used the word deception, I didn't mean to imply that there is a conspiracy. No doubt most scientists and enthusiasts are sincere in supporting their position in this issue, whatever that may be, but the idea that ethanol is a real option is clearly a fallacy at this time. And we need to think about the options that exist today.
Ethanol from corn may be an alternative fuel, but it is not an alternative.
Ethanol today could be considered largely an energy carrier rather than an energy source, but:
A.E. Farrell et al. said:
Our best point estimate for average performance today is that corn ethanol reduces petroleum use by about 95% on an energetic basis and reduces GHG emissions only moderately, by about 13%.
Ethanol today is effective at reducing U.S. dependence on foreign oil today. Ethanol may also have a future as a primary energy source.
Ivan Seeking said:
...the idea that ethanol is a real option is clearly a fallacy at this time. And we need to think about the options that exist today.
If you have an alternative in mind (biodiesel?) then please compare it to ethanol directly.
Although biofuels offer a diverse range of promising alternatives, ethanol constitutes 99% of all biofuels in the United States.
Ivan you haven't commented on my first post. My point is that you cannot count all of the fuel it takes to raise a crop since that crop is used for other things even after the alcohol is taken out. If you intend to calculate the amount of fuel it takes to get a unit of ethanol in the manner that they are in your post #39 then you have to assume that no crop was raised prior to ethanol production which is completely false and that no other products come from the crop once the ethanol is taken out which is also completely false. I do not wish to argue for or against ethanol from crops I just want to point out that the methods arrived at figuring gains/or losses are bogus.
Aether said:
Ethanol today could be considered largely an energy carrier rather than an energy source, but: Ethanol today is effective at reducing U.S. dependence on foreign oil today. Ethanol may also have a future as a primary energy source.
Estimates and three decades of testing indicates that by using algae, we can produce as much as a net 10,000 gallons of biodiesel per acre-year - say 7000 if we stay conservative and allow for a 30% processing demand. See the aquatic species program [in addition to plenty of more recent links found with a simple search] which predicted that algae could be competitive when diesel was at about $2 a gallon, or twice 1996 levels. [see part ii, page 4]
http://www1.eere.energy.gov/biomass/pdfs/biodiesel_from_algae.pdf
Not that we would want to, but a simple estimate suggests that we could replace all sources of energy - petro, coal, NG, hydro, nuclear, wind, solar - with about 400 X 400 miles of land and or water. In the process, algae can be grown while cleaning up CO2 or other industrial, agricultural, or municipal emissions or waste.
From everything that I have seen on the web and in my own testing, it was just a matter of time and price. It appears that algae became competitive [hit the break even point] about mid 2004 at ~40 a barrel for crude. It should be a viable option at today's prices.
Also, keep in mind that much of the literature focuses on making algae competitive at much lower prices, which it isn't, but today this is likely not an issue.
We can't play shell games: We have to look at the real costs to produce what we need. We have to assume that we create new farmland to produce the fuel since we clearly don't have enough now [unless we plan to stop producing food]. And byproducts are great, but when we start talking about twice the land area of the US, they don't count for much. It is clearly not a viable option in the big picture. But as I stated earlier, it might be used to ease the crunch as it is today.
I also suggest that even if we could grow enough corn, due to the amount needed, most byproducts would not be valuable due to supply and demand. This has already happened in the biodiesel market. One byproduct is pure glycerin, which now has relatively little value due to the amount of biodiesel produced.
However, as a best case perhaps, a byproduct of algae is... algae. :biggrin: After getting the biodiesel, in principle it can be used to produce ethanol, and then hydrogen, but I don't know if this has ever been done in a practical way. Also, people are working with algae for hydrogen and ethanol production alone, so the picture is bigger than just biodiesel, but down the road - another "future" option. Still, one important concept wrt algae is the carbon all goes somewhere - either as sugars for ethanol, or hydrocarbons [fatty acids] for biodiesel. As it turns out, the most efficient path today is for hydrocarbon production.
The residual mash can be used as a high quality feed for cattle, or as fertilizer for other food or algae crops.
Oh yes, 400 X 400 miles X 640 acres/ sq. mile X 10,000 gallons/acre X 118300 BTUs per gallon = 120 quads.
So maybe 80 quads in practice. Again, we use about 100 quads from all souces, and when you sort it out a bit, the efficiencies don't change the picture greatly. And to replace just petroleum, but all petroleum, which unlike ethanol, biodiesel could since it could be used in the trucking and other industries [and is currently being tested for aviation], we would only need about 39% of this, or about 250 X 250 miles of land or water [good farmland not needed]
But the point of this thread was to show that based on the technology that we have today, ethanol, and esp ethanol from corn, is not a long term solution to the energy problem. Some even argue that it is part of the problem [a net loser].
Late edits: Going to back a point made earlier, we can also reduce this requirement [land needed for algae] as we do use energy to transport crude from other counties, and then to refine it here. I think the avg chain efficiency for petro fuels is a little under 80%, so we can legitimately derate the requirements accordingly. I need to check on the exact number though; that is about what I think it was...
I'm not sure what you mean by 'play shell games'. The simple fact is that X acres of crop will be raised regardless of whether we take ethanol out or not. So until ethanol usage shorts some other product that requires the carbohydrate, NOT taking alcohol out is the most inefficient way to go. Residual mash left from ethanol from corn is also a high quality source of feed for cattle. It's a good protien source commonly known as distillers grain. I'm betting that there is a lot more residual left from corn after distillation than alcohol. We all need to remember that we need to eat too which has always been and hopefully always will be the main role of agriculture.
I'm certainly not saying that ethanol from corn is a cure all. Obviously it's not. My point is that the method arrived at determining the net gain/loss is bogus and you can't/won't see it.
The fact is, already the use of ethanol has doubled the corn prices - food and energy are in competition, and we see the result. And we have barely scratched the surface.
Where is that benefit again? Earlier I posted a Reuters quote showing that chichen prices have started to rise [up 6 cents a pound for wholesale at that time], and there is upward pressure on beef prices, all because of ethanol. There are already a million [figuratively speaking] uses for corn and corn products, and anything using these products will be affected.
And it is not true that demand for ethanol will have no impact on how much corn we grow - supply and demand says otherwise.
I would bet a years pay that corn prices will not stay at current levels for any length of time. And I'm not talking about a 5 to 10 year trend. If they do, everything else will inflate along with. In 1996 corn spiked well over $5.00 per bushel. It happens every so often. You are talking very short term. Take a look at corn prices over the last 30 years and you'll see what I mean. Food is already in competition with energy. It takes energy to get food and until everyone moves back to small farms and things go back to manual labor it will remain so.
Anyways, that is not my argument, so please don't even bother. My point is (which you've ignored) the method used to determine the net gain/loss of energy in ethanol production. Crops will continue to be grown as they always have so the same amount of fuel will be expended to do so with or without taking the ethanol out. It makes me wonder what else is overlooked in all of the other energy source schemes being dreamed up.
You seem to forget that we need the corn grown today. This is not a surplus grown for no reason.
The increased cost of corn is attributed directly to ethanol, but the other market forces still apply, so we would expect to see tremendously high spikes in the future if ethanol production increases significantly. When we apply the law of supply and demand, and we create a huge new demand, the prices will certainly rise accordingly. This is basic economics.
Another advantage that biodiesel has today [without even growing algae yet] is that the feedstock base is highly diversified - we can and do use many different kinds of plants as a source- so the impact can be spread out over many different products. For example, in some areas the source is canola, others cotton seed, and in many areas we make it from soybeans. Rapeseed is another strong source of feedstock today.
I think the majority of biodiesel in the US is coming from soybeans right now, but this is driven by demand. As the demand increases, more crops will come online with greater capacity. In principle it could help ALL farmers, and not just corn farmers.
I know that Willie Nelson [BioWillie] drives a Mercedes that runs on cotton seed biodiesel.
He has a sticker on the front window: No War Required. :biggrin:
A small correction: Since they were using E85 and not pure ethanol, considering just the reduced energy density we would expect to see about a 33% decrease in the mileage, which is getting very close to the 27% measured.
Ivan I'm NOT the one forgetting that we need the corn grown today, that's my whole point. It WILL BE GROWN REGARDLESS OF WHETHER WE TAKE ALCOHOL OUT. You seem to skip over the fact that the only thing taking the alcohol out does is remove the sugars from the corn. It is still quite useful after. I am not favoring ethanol over biodiesel at all. You speak of basic economics. Well here's some food for thought: Right now a corn/soybean crop rotation is fairly common. As there is more demand for corn more of these acres are switched over from soybeans to corn. We now raise corn on the same ground year after year on more acres than previously. This naturally affects the market price of soybeans and some other crops as there are less grown. The same thing will happen if the demand for ethanol goes down and the demand for biodiesel goes up. It will be more profitable to raise soybeans and other biodiesel crops so there will be less corn grown and this shortage will raise the price of corn. Take a look at the market price for both corn and soybeans over the last few years and you will find that they track each other.
If you don't want fuel to directly compete with food then keep energy production out of agriculture and find some other source for it.
Sure, it can be used for some applications, but what about those that need the corn intact? The fact is that we can't process all of the corn for ethanol which is already needed for other uses, but perhaps some could be.
I also want to be clear that I am not against ethanol because of biodiesel, rather, I became a biodiesel fan on its own merits, and have been very disappointed to learn about the reality of ethanol which I once saw as a promising option to petro.
Absolutely a valid point. Parts of the solution are the other crops like cotton, canola etc which helps to spread out the pain, but...
I see it like this: Biodiesel is superior to ethanol in many ways, not the least of which are: The diversified base of feedstock; 1.5 times the energy density; a more efficient [as a percent of yield] processing chain. Now, if we didn't have algae as a real option today, biodiesel would have the same problem as ethanol in that we couldn't possibly grow enough. But we do have the algae option, and macro plants are available today to help with the short term demand for biodiesel. In turn, biodiesel is the carrot to go diesel. So we go diesel, then biodiesel from all crops, then we begin to supplement the macro crops with algae until eventually it could supply the majority of the feedstock [of course, in reality these are concurrent events]. And most important of all, unlike ANY other option that I have ever seen, bio from algae offers a permanent solution - and one that need not compete with food.
If it wasn't for algae, there would be NO good options ready today that could actually solve the problem. [less nuclear, which I don't see as a practical reality in an age of terrorism even if we could build the plants fast enough, which we can't.]
Also, just to avoid any confusion, algae has been a practical option for some time, but it has not been competitive due to price...until now.
Biodiesel has 118330 BTUs per gallon. Ethanol has 76000 BTUs per gallon. This taken with the efficiency of the engine used for each fuel is a direct measure of the work that can be done with each gallon of that fuel. [118/76 ~= 1.5.]. Of course that 1.5 times ignores the greater efficiency of diesel over combustion engines, which makes the comparion even more drastic, as is seen below.
While we are still using regular diesel - as we convert to bio - we get 139,000 BTUs per gallon in engines that are more efficient than gasoline or ethanol powered engines. It begins to help even before we convert to bio. And the diesel cars are here or coming.
Diesel engines are already high compression engines, so the comparison is valid even if we consider engines not yet available for ethanol.
The higher energy density of bio, the greater efficiency of diesel engines, and the more efficient processing for bio suggests that Bio has about a 400% energy advantage over ethanol - every four gallons of ethanol produced can move a car down the road as far as every gallon of bio produced.
Ok. That is pretty much what I expected, but not everything I want to know. How many gallons per bushel of each? And how many bushels per acre of each?
Note that I have a bunch of late edits in the last post [struggling for clarity]
Most common stats cited for gross yields:
Corn yields 400 gallons of ethanol per acre-year.
Algae yeilds about 10,000 gallons of biodiesel per acre-year.
Net yields [after we pay the energy price to grow and process the fuel]:
Corn = 120 gallons per acre-year
Algae = 7000 gallons per acre-year
I just saw that BBC World News is running a story that asks the question: Should we grow food to feed the world's starving, or grow crops for fuel?
Corn yields 400 gallons of ethanol per acre-year...
Corn = 120 gallons per acre-year...
As I quoted earlier, according to A.E. Farrell: "Our best point estimate for average performance today is that corn ethanol reduces petroleum use by about 95% on an energetic basis...". Therefore, in order to compute "net yields" you need to be using 0.95 instead of 0.3; and then your number above for net yields would be "...Corn = 380 gallons per acre-year".
What about soybeans and other biodiesel crops? Also, what is figured in for inputs to the crop? On a corn/soybean rotation it is common to not use fertilizer at all for the soybeans. Plant food is derived from the residue of the previous years crop as well as some of the fertilizer applied for the corn crop. I guarantee you that soybeans on the same ground year after year will require some kind of fertilizer. I know next to nothing about algae but I have a very hard time believing that all it requires is air and sunlight. There must be other input to net the amount of biodiesel we are talking about.
The EBAMM model (ERG Biofuel Analysis Meta-Model) provides a thorough analysis of all inputs, including the agricultural phase, of ethanol production. I don't know if they provide similar information on biodiesel.
http://rael.berkeley.edu/EBAMM/.
