- 10,500
- 1,647
Jaime Rudas said:Is that "flat plane" two-dimensional or three-dimensional?
Two dimensional
If the paper is "hovering" statically, i.e., no radial or tangential motion, frame dragging has no effect.raagamuffin said:Then I read a reference to 'frame dragging' in rotational black holes. What effect, if any, will that have on the 'paper'?
PAllen said:In the side discussion of embedding a piece of a plane smoothly, isometrically, in a 3-sphere (following is part of a response to @pervect 's last post:
I thought I would make explicit the construction in that reference (which is presented it very compactly in any number of dimensions). Making it explicit for flat 2-surface section in a 3-sphere, the mechanism is simply to use a properly sized flat torus. As explained in:
https://en.wikipedia.org/wiki/Clifford_torus
a flat torus of just the right size will smoothly fit in a unit 3-sphere, both embedded in R4. But then, the embedding can be just ignored, and you are left with a smooth embedding of a piece of Euclidean plane in a 3-sphere.
The formalization and generalization of this is the general approach to embedding ##E^n## into higher dimesnsional spheres used in the reference I quoted earlier. The general achievement is a local embedding of ##E^n## into an m-sphere, with ##m=2n-1##.
More precisely, by the Riemann curvature tensor that's derived from a metric via its Levi-Civita connection. There's no problem with that--that's how the term is being used in this discussion.pervect said:I'm viewing curvature as being defined by a metric.
When discussing isometric embeddings, there is a little more to it. The metric of the submanifold is taken to be induced from the manifold metric. This means that, e.g. the distance along a curve on the 2-sphere embedded in E3 is, in fact required to be that same whether you use the manifold metric or the induced metric on the 2-sphere. You get to choose manifold, its metric, and the definition of the submanifold embedded in it as a set of points. You do not then get to choose an arbitrary metric on the submanifold - it is taken to be that induced by the manifold metric.PeterDonis said:The reason it's possible is that the 2-sphere embedded in Euclidean 3-space is a submanifold of that 3-space, and we can define a metric on the submanifold that is curved even though the metric of the 3-space overall is flat. They're simply two different metrics. Note that those metrics give different answers to questions like the distance between two points, even if we restrict the points under consideration to those on the 2-sphere.
Yes. It's important to recognize also that the curve in question is a geodesic of the curved 2-sphere, but it is not a geodesic of the Euclidean 3-space. Considering the implications of that might help @pervect to see what's going on in such cases.PAllen said:the distance along a curve on the 2-sphere embedded in E3 is, in fact required to be that same whether you use the manifold metric or the induced metric on the 2-sphere.
What does "unit" mean in this context?PAllen said:a flat torus of just the right size will smoothly fit in a unit 3-sphere
Radius of curvature = 1Jaime Rudas said:What does "unit" mean in this context?
In what sense the pseudo-sphere isn't "a global embedding – the complete unbounded hyperbolic plane in ##E^3##"? Is it, perhaps, because its "equator" is a "bound" (a singularity)?PAllen said:[...] they state that you can’t smoothly isometrically embed any part of hyperbolic plane in Euclidean 3 space without crinkling or folding, [...] the pseudo-sphere is a trivial refutation of the false claim (the true claim, proved long ago by Hilbert, is about the impossibility of a global embedding – the complete unbounded hyperbolic plane in ##E^3## (Euclidean 3-space)).
No, because its total surface area is finite. It is actually just a small piece of the hyperbolic plane, it just 'looks' big in cartesian coordinates in ##E^3##.Jaime Rudas said:In what sense the pseudo-sphere isn't "a global embedding – the complete unbounded hyperbolic plane in ##E^3##"? Is it, perhaps, because its "equator" is a "bound" (a singularity)?
Ah, yes, now I understand: its area is equal to that of a sphere of the same radius 4πR².PAllen said:No, because its total surface area is finite. It is actually just a small piece of the hyperbolic plane, it just 'looks' big in cartesian coordinates in ##E^3##.
Charged rotating black holes can have a magnetic field, yes. We do not expect such fields to be very strong in practice because of the overall electric charge neutrality of the universe - an electrically charged black hole will attract oppositely charged matter and zero out its charge.raagamuffin said:If the black hole has a magnetic field (separately, do/should all BHs have a magnetic field?) would a triangle drawn on this sheet of paper be stretched differently?
No, because you can have curvature in vacuum regions. Generally, curvature depends on the distribution of stress-energy throughout the past light cone of the region you are interested in. Or, in the case of black hole spacetimes which are everywhere vacuum, presumably it depends on the presence of singularities.raagamuffin said:The equations indicate that the curvature of spacetime is dependent on the mass and energy (including EM) in the area of interest (I’m still not sure if that is a point volume or an arbitrary volume).
Yes.Ibix said:Generally, curvature depends on the distribution of stress-energy throughout the past light cone of the region you are interested in.
No. An "eternal" black hole, which truly is vacuum everywhere, is not a physically realistic solution; it's an idealized piece of math. The "mass" of the hole is just a parameter in the math--a constant that shows up in the metric. It is not "located" anywhere in particular, certainly not at the singularity.Ibix said:Or, in the case of black hole spacetimes which are everywhere vacuum, presumably it depends on the presence of singularities.
raagamuffin said:To follow up, I have been trying to learn the math around BH, to try and develop my own conclusions. Where I started is Einstein’s field equations and am currently meandering through tensor world.
There are references to the Einstein Maxwell system (still mulling over this), but I didn’t quite grasp what that means for the effect it contributes to the curvature. I also saw solutions around Reissner-Nordstrom , Kerr-Newman etc.
The answer seems to be , it depends on the magnetic field, and I read something about a Schwinger limit which seems to dictate at what scales EM will truly matter.
I think I’m on the right track here.
Although, the math is currently incomprehensible to me, and I blew a couple of fuses trying to decipher it ;) They say patience is a virtue, whether that will translate to actual mathematical understanding remains to be seen :)
baez and bunn said:Before stating Einstein’s equation, we need a little preparation. We assume the
reader is somewhat familiar with special relativity — otherwise general relativity
will be too hard. But there are some big differences between special and general
relativity, which can cause immense confusion if neglected.
In special relativity, we cannot talk about absolute velocities, but only rel-
ative velocities. For example, we cannot sensibly ask if a particle is at rest,
only whether it is at rest relative to another. The reason is that in this theory,
velocities are described as vectors in 4-dimensional spacetime. Switching to a
different inertial coordinate system can change which way these vectors point
relative to our coordinate axes, but not whether two of them point the same
way.
