Euler-Lagrange equation derivation
4 replies · 4K views
silmaril89
I'm trying to understand the derivation of the Euler-Lagrange equation from the classical action. http://en.wikipedia.org/wiki/Action...93Lagrange_equations_for_the_action_integral" has been my main source so far. The issue I'm having is proving the following equivalence:
[tex] \int_{t_1}^{t_2} [L(x_{true} + \varepsilon, \dot{x}_{true} + \dot{\varepsilon},t) - L(x_{true}, \dot{x}_{true},t)] \mathrm{d}t = \int_{t_1}^{t_2} (\varepsilon \frac{\partial L}{\partial x} + \dot{\varepsilon} \frac{\partial L}{\partial \dot{x}}) \mathrm{d}t[/tex]
I understand the idea behind their equivalence intuitively, The derivative of a function is the change in that function, and I see how on the left side there is a representation of a small change in the lagrangian, but I'm having a hard time proving this to myself mathematically and I'd like some help.
I understand all the other steps shown in the derivation.
Thanks to anyone that responds.
You should ignore the integral, and just focus on showing that the things under the integrals are equal. If you have a function f(x), then by definition of the derivative:
[f(x+h)-f(x)]/h=f'(x)
when h goes to zero.
Therefore f(x+h)-f(x)=h*f'(x)
This is for one variable, and the generalization to two variables is:
f(x+h,y+g)-f(x,y)=h*Dxf+g*Dyf
where Dx and Dy are the partial derivatives in the x-direction and y-direction respectively.
So just let y be x dot, and f be your Lagrangian, and you get the result.
Ok, that makes sense. I understand how it works with just one independent variable, but I did not realize the generalization to two variables. Thanks for that.
silmaril89 said:
Ok, that makes sense. I understand how it works with just one independent variable, but I didn't not realize the generalization to two variables. Thanks for that.
O, I didn't know that you know how it works with one variable. In that case:
f(x+h,y+g)-f(x,y)=[f(x+h,y+g)-f(x,y+g)]+[f(x,y+g)-f(x,y)]=
h*Dxf(x,y+g)+g*Dyf(x,y)
which you get just from the 1-variable definition of the derivative.
Now the key is that applying the one variable definition of the derivative again:
h*Dxf(x,y+g)=h*Dxf(x,y)+g*h*DxDyf(x,y)
and if g and h are really small, just keep the first term.
So f(x+h,y+g)-f(x,y)=h*Dxf(x,y+g)+g*Dyf(x,y)=h*Dxf(x,y)+g*Dyf(x,y)
Thanks for clearing that up for me. That's a clever trick to apply the one variable definition again. To be honest, it's bit unsettling to me that we disregard a term based on g and h being very small. However, I do realize in the derivation on the wikipedia page I linked that that term would be very small.
