Can a Polynomial Equation Generate All Primes? A Proof for Euler's Polynomial
  • Context: Graduate
  • Thread starter Thread starter khotsofalang
    Polynomial Proof
Euler's polynomial equation P(n) = n² + n + 41 does not generate all prime numbers, as proven by counterexamples. A general theorem states that no polynomial can produce only prime numbers for all positive integers. The discussion references a proof that shows if P(x) yields a prime p for n, then P(n + kp) is composite for all integers k, indicating that the polynomial is constant rather than a true polynomial. Additionally, while polynomials in multiple variables can generate primes, they also produce composite numbers, especially as variable sizes increase.
  • Understanding of polynomial functions and their properties
  • Familiarity with prime number theory
  • Knowledge of modular arithmetic
  • Basic concepts of Diophantine equations
  • Study the implications of Matiyasevich's theorem on Diophantine equations
  • Explore the properties of the Jones polynomial and its relation to prime generation
  • Investigate the proof that no polynomial can generate all primes, as detailed on Wikipedia
  • Learn about polynomial inequalities in multiple variables and their applications
Mathematicians, number theorists, and anyone interested in the relationship between polynomials and prime number generation.
khotsofalang
without using a counter example, show a proof that Euler's polynomial equation P(n)=n^2+n+41 can not be used to generate all the primes.can a general proof be made to show that all primes cannot be generated by a specific polynomial?
Well, what, exactly, is "Euler's polynomial equation"? Don't you think that is important?
thats the proposition made by Euler that P(n)=n^2+n+41 can generate all primes and it was suddenly proven false by using a counter example, isn't there any way he can be proven to be false?
I believe you mean that P(n) would be prime for positive integers n, but there is now a general proof out there that no polynominal equation can generate only primes for all positive integers. I am sure that someone can cive you a link to a proof.
See also http://en.wikipedia.org/wiki/Formula_for_primes Euler's formula for primes as posted in this thread was once widely thought to generate primes for any integer n, but as shown by this link that was false. The proof is simple an noted in the link. Assume that P(x) is a polynominal in x that gives a prime p for the value n.
But then p|P(n+kp) for all integer k so these numbers must be composite for every k so the polynominal is a constant, p, rather than a polynominal.
P.S. Euler never said that the polynominal generated "all primes", but then that is obviously not what you meant is it?
It is possible with polynomials in more variables, as the same wiki article points out:
...is a polynomial inequality in 26 variables, and the set of prime numbers is identical to the set of positive values taken on by this polynomial inequality as the variables a, b, …, z range over the nonnegative integers.
A general theorem of Matiyasevich says that if a set is defined by a system of Diophantine equations, it can also be defined by a system of Diophantine equations in only 9 variables. Hence, there is a prime-generating polynomial as above with only 10 variables. However, its degree is large (in the order of 10^45). On the other hand, there also exists such a set of equations of degree only 4, but in 58 variables (Jones 1982).
That doesn't count - look at the restriction placed on both the input and output variables.
but the same polynominal would generate composites also with large enough variables. Think how easy it would be to exceed the largest prime otherwise
P(n) = n^2 + n + 41 =>
P(40) = 40^2 + 40 + 41
= 40 * 40 + 40 + 41
= 40 * 41 + 41 = 41 * 41 = composite.
The positive values of the Jones polynomial for positive values of the variables are always primes and all primes can be obtained this way. The problem is just that the probability that a random choice of the input vaiables will yield a positive value is astronomically small. If finally, after billions of years of trying, some positive value is obtained, it will likely be a prime number like 23.
robert Ihnot said:
That no polynominal can generate all primes is easily shown using the reference given already http://en.wikipedia.org/wiki/Formula_for_primes
Let P(1) = a prime S. Then P(1+kS) \equiv P(1) \equiv 0 Mod S.
Was that in response to my post? I was incredulous about the claim that "once widely thought to generate primes for any integer n". It's obvious that no nonconstant polynomial can produce primes for all n, so it's hard for me to believe that this was ever believed. But it could be true, so I was looking for ramsey2879 or someone else to comment on that.
I am 60 and some years old so I some times don't remember exactly what I read too well. The book is up in the attic. Some time I will look again at what was said about the polynominal. But that the polynominal does give composite values is of course easily shown.
If you do, I'd appreciate the effort if you post it.
  • · Replies 0 ·
