How Much Water for Evacuated Tube Solar Oven to Stay Below 120 PSI?
  • Thread starter Thread starter aluminumholds
    Steam Tube
The discussion focuses on the construction of an evacuated tube solar oven using half-inch type K copper pipes and water as a heat transfer fluid. The user aims to maintain a maximum pressure of 120 psi while achieving temperatures up to 400°F. Key insights include the importance of keeping vapor pressure below 120 psi, which allows for any volume of water, and the necessity of using saturated steam to effectively capture latent heat during condensation. The provided steam tables serve as a critical resource for understanding pressure and temperature relationships.
  • Understanding of evacuated tube solar oven design
  • Knowledge of pressure-temperature relationships in steam systems
  • Familiarity with type K copper pipe specifications
  • Basic principles of heat transfer fluids
  • Research the properties of saturated steam and its implications for heat transfer
  • Learn how to use steam tables for pressure and temperature calculations
  • Explore methods for controlling temperature in solar thermal systems
  • Investigate safety measures for operating under high pressure in solar ovens
Individuals interested in solar thermal energy systems, engineers designing solar ovens, and hobbyists building evacuated tube solar collectors will benefit from this discussion.
aluminumholds
Hey everyone,
I'm building my first evacuated tube solar oven and I seem to run into a problem I can't get around. First of all, I am going to use half inch type K copper pipes with water as a heat transfer fluid. I am putting a vacuum (100 mbar or so) on the tubes to lower the boiling point of the water. The tubes are about 10 feet long, giving me a volume of 23.56 in^2. I'm doing this in order to have the water in vapor form most of the time in order to superheat the steam and achieve temperatures higher than 212F. If my highest pressure can be 120 psi, according to Copper.org which describes pressure rating for brazed joints using saturated steam, what is the amount of water I need to add to the pipes in order not to exceed that pressure?
Thanks in advance for your help and advice, it'll really help me out :)
What is the maximum temperature you are looking to operate at?
BoB
400F would be my max temperature in the heat pipes.
This http://www.slideshare.net/muhammad_anam/steam-tables
might be helpful. I don't know how to calculate for your situation. I just know that the temperature is important.
If you keep the vapor pressure below your 120psi then any amount of water is OK. Could you limit the temperature to 340F? If I am reading the linked tables correctly you then stay below 120psi at any volume. You would also keep a liquid phase at all times.
BoB
Thanks for the table BoB, they'll definitely be useful. As of know I don't have a way to limit temperatures...however I've done some more reading and know that I need to have saturated steam, not superheated steam; to capture the latent heat of water condensing.
10K
42K
9K
