Evaluate this trigonometric identity
55 replies · 6K views
lioric
If tanx = 4/3 and π < x < 3π/2 , evaluate the following
(Sinx-2cosx) / (cotx-sinx)
Tan x=sinx/cosx
Cotx=1/tan
(Sinx-2cosx)/ (cotx - sinx)
Substitute tan instead of cot
(Tanx(sinx-2cosx)/(1-sinx)
What do I do from here
I don't think what I did there is correct
That's why I didn't expand the tan to sin/cos
on Phys.org
PeroK said:
Have you ever heard of a 3-4-5 triangle?
Ya triangles which have their lengths in that ratio which fits them into pythagorean triples
So can you draw a triangle involving the angle ##x##?
I can understand what you're saying because tanx = 4/3 where 4 is opposite and 3 is adjacent
Ok I have drawn a triangle
So now can you evaluate ##\sin{x}## and ##\cos{x}##?
Sinx = 4/5
Cox = 3/5
So that question is asking me to just put in those values?
Is there a trigonometric identity method for this where we substitute tan and stuff?
  • Sad
lioric said:
Sinx = 4/5
Cox = 3/5
On a given range, ##\tan x## is one-to-one. If you know the value of ##\tan x## you know the value of ##x##, hence you know the value of ##\sin x## and ##\cos x##. All you need is Pythagoras.
Do you know the term "quadrant"?
Ya that circle thing which shows which of the trigonometric function are positive or negative
So what are the signs of those functions in the third quadrant?
180 and 270 the third quadrant
Indeed, but if the angle to the positive ##x## axis of a line segment from the origin to a point on the unit circle is ##\theta##, then the coordinates of that point are ##(\cos{\theta}, \sin{\theta})##.
That should help you to work out the signs!
Could you emphasis on that last point again
🎉🎉That should help you to work out the signs!🎉🎉
Just kidding. The question tells you that the angle is in the third quadrant, and from the unit circle you can easily determine whether each of sin/cos/tan is positive or negative in that quadrant. Some people call it a "CAST diagram":
  • Haha
Ahh ok
Now I like this method
But I was wondering if there is another method of doing this by a simplification sort of way like by substituting tan into the mix and finding the value at the end
  • Sad
lioric said:
Ahh ok
You mean a method where you don't have to think, but just look up a formula and plug in the numbers?
No no no. Not like that. Like you put in tan expand it to sin/cos and cancel some stuff like that
It should be fairly obvious how to do that. Remember that ##\sin^2 x + \cos^2 x = 1##.
And ##\sec^2 x = 1 + \tan^2 x##.
Sometimes a few right angled triangles can save you from working with lots of identities. For instance, consider the Weierstrass substituion, ##t = \tan{\frac{\theta}{2}}##:
Of course, you still need to remember some double angle formulae.
Yes I know this is a very nice method. But in this case this is very specific for this question because of the parameters given.
But I'm weak in the identity department. So I'd like to work on that too. Could you please show me
Could you show me how that fits into this situation
PeroK said:
I think it's time you made your best effort to solve this problem.
Ok thank you I'll post my progress
Here is what I got so far. Now where do I go from here?
I know the triangle method. As posted above etotheipi has shown that very well and I understand that.
id also want to know the identity method of doing this because I’m weak at that
In any case I can't see how the second line follows from the first. If anything, it should be ##\frac{\sin^2 x - \sin{2x}}{\cos{x} - \sin^2{x}}##, no?
Is it really so difficult to express ##\cos x## in terms of ##\tan x##? I gave you the formula in a previous post:
I'd like to see you get the answer by that method. At least that means you know when you get the right answer by any other method.
How did that cos become a sin?
The cos was given in the question
