Evaluating ∫₁^(e^(π/2)) sin(ln x) dx
  • Thread starter Thread starter Doc G
    Integral
10 replies · 6K views
Doc G
Hi,
find value of
[tex] \int_{1}^{e^\frac{\pi}{2}} \sin (lnx) dx[/tex]
I first used subsitution u = lnx, that gave me:
[tex] \int_{0}^{\frac{\pi}{2}} e^{u}\sin u du[/tex]
then letting
[tex] I = \int_{0}^{\frac{\pi}{2}} e^{u}\sin u du[/tex]
integrating by parts twice, gave me:
[tex] I = - e^{u} \cos u +\int_{0}^{\frac{\pi}{2}} u e^{u}\cos u du[/tex]
[tex] I = - e^{u} \cos u + e^{u} \cos u + \int_{0}^{\frac{\pi}{2}} e^{u}\sin u du[/tex]
therefore
[tex] I = - e^{u} \cos u + e^{u} \cos u + I[/tex]
which of course cancels to zero which is not very useful
Any ideas on finding the value of this integral, or have i made an error in my working?
Many Thanks
I think you need to re-check the 'by-parts'.
Yep. In particular, in the second "by parts", think where that sine inside the integral comes from :)
Taking the result of the first integration by parts:
then working with the integral part:
[tex] +\int_{0}^{\frac{\pi}{2}} u e^{u}\cos u du[/tex]
let u= cos u
therefore
[tex] \frac{du}{dx}= - sinu[/tex]
let
[tex] \frac{dv}{dx}= u e^{u}[/tex]
therefore
[tex] v = e^{u}[/tex]
then using identity that:
[tex] \int u \frac{dv}{dx} \equiv uv - \int v \frac{du}{dx}[/tex]
I got
[tex] e^{u} \cos u + \int_{0}^{\frac{\pi}{2}} e^{u}\sin u du[/tex]
Note- i chose u=cos u and dv/dx =ue^u [rather than u=ue^u]since i thought otherwise I would never be able to achieve an equivalent expression without an integral involved as I would get greater and greater powers of u in front of e^u as I kept going.
Sorry if I'm not seeing something obvious, but i can't find the error there
thanks for the replies
Doc G said:
Note- i chose u=cos u and dv/dx =ue^u [rather than u=ue^u]since i thought otherwise, I thought I would never be able to achieve an equivalent expression without an integral involved as I would get great and great powers of u in front of e^u as I kept going.
How did you get a 'u' within the integral at the result of the first integration by parts? (And it's now the derivative with respect to u, not x)
[I'm using t instead of u for the sake of clarity]
The first integral, after substitution [tex]= \int_{0}^{\pi/2}{e^t\sin{t}}dt[/tex]
Let u = cos(t) and dv/dt = e^t. Therefore, du/dt = -sin(t) and v = e^t.
Thanks, I think I've got it now; but just to check here my full working:
let
[tex] I = \int_{0}^{\frac{\pi}{2}} e^{t}\sin t dt[/tex]
u = sin t
dv/dt= e^t
therefore
du/dt = cos t
v = e^t
so:
[tex] I = e^{t} sin t - \int_{0}^{\frac{\pi}{2}} e^{t} cos t dt[/tex]
and integrating by parts again:
u = cos t
dv/dt = e^t
so
du/dt = -sin t
v = e^t
[tex] I = e^{t} sin t - e^{t} cos t - \int_{0}^{\frac{\pi}{2}} e^{t} sin t dt[/tex]
[tex] I = e^{t} sin t - e^{t} cos t - I[/tex]
[tex] 2I = [e^{t} ( sin t - cos t )]_{0}^{\frac{\pi}{2}}[/tex]
[tex] I = \frac{1}{2} [(e^{\frac{\pi}{2}}( 1 - 0 )) - ( -1)][/tex]
and finally, giving
[tex] I = \frac{1}{2} [e^{\frac{\pi}{2}} + 1 ][/tex]
Hopefully its right this time?
Thanks again
Hmm, I don't quite follow what you're doing in your subsequent posts (it looks correct though), but your first try was already correct if it weren't for one minus sign:
then letting
[tex] I = - e^{u} \cos u + e^{u} \cos u - \int_{0}^{\frac{\pi}{2}} e^{u}\sin u du[/tex]
Note the minus sign: cos' = -sin[/color]
therefore
[tex] I = - e^{u} \cos u + e^{u} \cos u - I[/tex]
so
[tex]2I = - e^{u} \cos u + e^{u} \cos u[/tex]
and the answer follows.
so
And you end up with 0, which is incorrect.
