Evaluating ∫₁² (2e^(-4x) - 1/x²) dx
4 replies · 3K views
zeno23
Evaluate the definite integral.
[tex] \int_{1}^{2} ( 2e^{-4x} -\frac{1}{x^2} ) dx[/tex]
Answer given by the book: [tex]\frac{1}{2}(e^{-4}-e^{-8}-1)[/tex]
u = 4x; x = u/4; du = 4 dx; dx = du/4;
[tex]\frac{1}{2}\int e^{-u} du - 4\int u^{-2} du[/tex]
[tex]\frac{1}{2}\int_{1}^{2} e^{-4x} dx - 4\int_{1}^{2} \frac{1}{16x^2} dx[/tex]
... and I continue down this path to wind up with:
[tex]\frac{1}{2e^8}-\frac{1}{2e^4}-\frac{21}{32}[/tex]
In other words, I've apparently no idea what I'm doing, and would appreciate any help.
Split the integral into two integrals:
[tex]\int_{1}^{2} 2e^{-4x} dx - \int_{1}^2 x^{-2}} dx[/tex]
It looks like you are letting your substitution slop over into the 2nd part of your integral.
For your substitution use u = -4x, so du = -4 dx.
After you have found an antiderivative for the 1st integral, undo your substitution and evaluate the antiderivative at x = 2 and x = 1.
Alternatively, you can write new limits of integration for the 1st integral by converting the two values of x into values of u.
Wait, I got it. It should just be e^u, so e^(-4*2). /facepalm
Thanks again.
Thanks for the response. I've managed to arrive at the proper answer, but I don't grasp the logic completely. I start with:
[tex]\int_{1}^{2} 2e^{-4x}[/tex]
I set u=-4x and dx=(-1/4) du, so then:
[tex]- \frac{1}{2} \int e^u du = -\frac{ e^{ \frac{u^2}{2} } }{2}[/tex].
Putting this back into terms of X, I get: [tex]-\frac{e^{\frac{(-4x)^2}{2}}}{2}[/tex]
But I it looks like it should be [tex]-\frac{e^{-4\frac{x^2}{2}}}{2}[/tex]. When I use this, I get the proper answer. Since u=(-4x), why do we multiply x^2 by -4 in the final step rather than (-4x)^2 ?
BTW, in your original work, you used the same substitution on the 2nd part of your integral, which is the wrong thing to do.
