Evaluating A-Matrix Transformation for Hemitian Operator
24 replies · 6K views
Bill Foster
Suppose that [tex]f\left(A\right)[/tex] is a function of a Hemitian operator A with the property [tex]A|a'\rangle=a'|a'\rangle[/tex]. Evaluate [tex]\langle b''|f\left(A\right)|b'\rangle[/tex] when the transformation matrix from the a' basis to the b' basis is known.
[tex]\langle\beta|A|\alpha\rangle=\int dx' \int dx'' \langle\beta|x'\rangle\langle x'|A|x''\rangle \langle x''|\alpha\rangle=\int dx' \int dx'' \psi_\beta^*\left(x'\right)\langle x'|A|x''\rangle\psi_\alpha\left(x''\right)[/tex]
Transformation from [tex]a'[/tex] to [tex]b'[/tex] basis:
[tex]U|a'\rangle = |b'\rangle[/tex]
Multiply both sides by [tex]a''[/tex]:
[tex]\langle a''|U|a'\rangle = \langle a''|b'\rangle[/tex]
This is the transformation matrix.
Now insert [tex]|a''\rangle\langle a''|[/tex] into [tex]\langle b''|f\left(A\right)|b'\rangle[/tex]:
[tex]\langle b''|f\left(A\right)|a''\rangle\langle a''|b'\rangle[/tex]
Now insert [tex]|a'\rangle\langle a'|[/tex] into the above:
[tex]\langle b''|a'\rangle\langle a'|f\left(A\right)|a''\rangle\langle a''|b'\rangle[/tex]
This is a transformation matrix: [tex]\hat{T}=\langle a''|b'\rangle[/tex]
And so is this: [tex]\hat{T}^*=\langle b''|a'\rangle[/tex].
So then:
[tex]\langle b''|f\left(A\right)|b'\rangle = \hat{T}^* \langle a'|f\left(A\right)|a''\rangle \hat{T}[/tex]
No it isn't. In fact, it isn't even a matrix; just an inner product between two states.
What makes you think you are allowed to do this?
Again, not matrices. Also, [itex]\langle a''|b'\rangle^{\dagger}=\langle b'|a''\rangle\neq\langle b''|a'\rangle[/itex]
So then:
If you have [tex]\langle b''|f\left(A\right)|b'\rangle[/tex], why not just insert [tex]\sum_{a'}|a'\rangle\langle a'|[/tex] in there so you can get the eigenvalue of [tex]f(A)[/tex]:
[tex] \sum_{a'}\langle b''|f(A)|a'\rangle\langle a'|b'\rangle=\sum_{a'}f(a')\langle b''|a'\rangle\langle a'|b'\rangle[/tex]
Ahhh...I looked at Sakurai a little closer. You're right.
Section 1.5:
"The matrix elements of the U operator are built up of the inner products of old base bras and new base kets."
If Chuck Norris can divide by zero, then I can do that.
If
Then
[tex]f\left(A\right)|a'\rangle=f\left(a'\right)|a'\rangle[/tex] ??
I was wondering how that eigenvalue relationship came into play in this problem.
Thanks.
Bill Foster said:
If
Then
Thanks.
Yeah, you can prove this by Taylor expanding some function and then applying the ket, for example the exponential function:
[tex] \begin{array}{ll}\exp[mA]|a'\rangle&=\left(1+mA+\frac{m^2A^2}{2!}+\cdots\right)|a'\rangle<br /> \\ \,&=|a'\rangle+mA|a'\rangle+\frac{m^2}{2!}A^2|a'\rangle+\cdots<br /> \\ \,&=|a'\rangle+ma'|a'\rangle+\frac{m^2}{2!}(a')^2|a'\rangle+\cdots<br /> \\ \,&=\left(1+ma'+\frac{(ma')^2}{2!}+\cdots\right)|a'\rangle<br /> \\ \,&=\exp[ma']|a'\rangle[/tex]
So here's what I came up with. Please let me know how it looks:
[tex]\langle b^{(m)}|f\left(A\right)|b^{(n)}\rangle[/tex]
Insert the following:
[tex]\sum_k |a^{(k)}\rangle \langle a^{(k)}|[/tex]
[tex]\sum_l |a^{(l)}\rangle \langle a^{(l)}|[/tex]
[tex]\sum_k \sum_l \langle b^{(m)}|a^{(k)}\rangle \langle a^{(k)}|f\left(A\right)|a^{(l)}\rangle \langle a^{(l)}|b^{(n)}\rangle[/tex]
[tex]=\sum_k \sum_l f\left(a^{(l)}\right) \langle b^{(m)}|a^{(k)}\rangle \langle a^{(k)}|a^{(l)}\rangle \langle a^{(l)}|b^{(n)}\rangle[/tex]
[tex]=\sum_k \sum_l f\left(a^{(l)}\right) \langle b^{(m)}|a^{(k)}\rangle \delta_{kl} \langle a^{(l)}|b^{(n)}\rangle[/tex]
[tex]=\sum_k f\left(a^{(k)}\right) \langle b^{(m)}|a^{(k)}\rangle \langle a^{(k)}|b^{(n)}\rangle[/tex]
[tex]=\sum_k f\left(a^{(k)}\right) \langle a^{(m)}|U^{\dagger}|a^{(k)}\rangle \langle a^{(k)}|U|a^{(n)}\rangle[/tex]
[tex]=f\left(a^{(k)}\right) \langle a^{(m)}|U^{\dagger}U|a^{(n)}\rangle[/tex]
[tex]=f\left(a^{(k)}\right) \langle a^{(m)}|a^{(n)}\rangle[/tex]
[tex]=f\left(a^{(k)}\right) \delta_{nm}[/tex]
It looks like you don't actually need to add [tex]|a^{(k)}\rangle\langle a^{(k)}|[/tex] in the above, but otherwise seems fine to me.
Any ideas on how to do part (b)?
I'm approaching it the same way, with some differences:
[tex]\langle \textbf{p}''|F\left(r\right)|\textbf{p}'\rangle[/tex]
[tex]= \sum_{\textbf{x}'} \sum_{\textbf{x}''}\langle \textbf{p}''|\textbf{x}''\rangle \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle \langle \textbf{x}'|\textbf{p}'\rangle[/tex]
[tex]\langle \textbf{x}'|\textbf{p}' \rangle = \frac{1}{\left(2\pi\hbar\right)^{\frac{3}{2}}}e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}[/tex]
[tex]= \sum_{\textbf{x}'} \sum_{\textbf{x}''}\frac{1}{\left(2\pi\hbar\right)^{\frac{3}{2}}}e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle \frac{1}{\left(2\pi\hbar\right)^{\frac{3}{2}}}e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}[/tex]
[tex]= \frac{1}{\left(2\pi\hbar\right)^{3}} \sum_{\textbf{x}'} \sum_{\textbf{x}''}e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}[/tex]
Now I'm stuck.
[tex]\frac{1}{\left(2\pi\hbar\right)^{3}} \int \int e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x' d^3x''[/tex]
Does this work here?
[tex]F(r)|\textbf{x}'\rangle = F(x')|\textbf{x}'\rangle[/tex]
If it does, then:
[tex]\frac{1}{\left(2\pi\hbar\right)^{3}} \int \int F\left(x'\right)e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |\textbf{x}'\rangle e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x' d^3x''[/tex]
[tex]=\frac{1}{\left(2\pi\hbar\right)^{3}} \int \int F\left(x'\right)e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \delta^3\left(\textbf{x}''-\textbf{x}'\right) e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x' d^3x''[/tex]
[tex]=\frac{1}{\left(2\pi\hbar\right)^{3}} \int F\left(x'\right)e^{-i \frac{\textbf{p}''\cdot\textbf{x}'}{\hbar}} e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x'[/tex]
[tex]=\frac{1}{\left(2\pi\hbar\right)^{3}} \int F\left(x'\right)e^{-i \frac{\textbf{x}'}{\hbar}\cdot\left(\textbf{p}''-\textbf{p}'\right)}d^3x'[/tex]
while [tex]r=\sqrt{x^2+y^2+z^2}[/tex], you can't make this claim. You'l have to solve this integral as a function of [tex]F(\mathbf{r})[/tex]. Also, an integral is also a sum so
[tex] \sum_{a'}|a'\rangle\langle a'|=\int|a'\rangle\langle a'|\,da'=1[/tex]
Basically your last post has it mostly right, though you can't use [tex]F(x')[/tex]. Expanding the integral for spherical coordinates:
[tex] \langle \mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{1}{\left(2\pi\hbar\right)^3}\int_0^{2\pi}d\phi'\int_{-1}^1d(\cos\theta)\int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}''|\cdot\mathbf{r}}{\hbar}\right]\,dr'[/tex]
Now I'm stuck.
As before, I don't think you need the double sum. You should just have
[tex] \begin{array}{ll}\langle \textbf{p}''|F\left(\mathbf{r}\right)|\textbf{p}'\rangle&= \sum_{\textbf{r}'} \langle \textbf{p}''|F\left(\mathbf{r}\right)|\textbf{r}'\rangle \langle \textbf{r}'|\textbf{p}'\rangle<br /> \\ &=\sum_{r'}F(\mathbf{r}')\langle\mathbf{p}''|\mathbf{r}'\rangle\langle\mathbf{r}'|\mathbf{p}'\rangle\end{array}[/tex]
note the use of [tex]\mathbf{r}[/tex] instead of [tex]\mathbf{x}[/tex] because [tex]F[/tex] is a function of [tex]r[/tex], not [tex]x[/tex].
Actually, this last line should read
[tex] \langle \mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{1}{\left(2\pi\hbar\right)^3}\int_0^{2\pi}d\phi\int_{-1}^1d(\cos\theta)\int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}''|r'\cos\theta}{\hbar}\right]\,dr'[/tex]
I just forgot to remove the vector off of [tex]\mathbf{r}'[/tex], but is otherwise correct as is
Yeah...I made a mistake on this post and since we can't delete them, I'm just erasing it all. You should be fine with what I had written in posts 15 and 16.
When I say [tex]\textbf{x}[/tex], I mean [tex]\textbf{x}=x\hat{\textbf{x}}+y\hat{\textbf{y}}+z\hat{\textbf{z}}[/tex]
And [tex]\textbf{x}'=x'\hat{\textbf{x}}+y'\hat{\textbf{y}}+z'\hat{\textbf{z}}[/tex]
So evaluate this:
[tex]\langle\mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{1}{\left(2\pi\hbar\right)^3}\int_0^{2\pi}d\phi\int_{-1}^1d(\cos\theta)\int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}'|r'\cos\theta}{\hbar}\right]\,dr'[/tex]
And get this:
[tex]\langle\mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{4\pi}{\left(2\pi\hbar\right)^3} \int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}'|r'\cos\theta}{\hbar}\right]\,dr'[/tex]
What next? integrate by parts?
Looks like integrating by parts will get rid of the exponential leaving me something in terms of [tex]F(r')[/tex].
Bill Foster said:
So evaluate this:
And get this:
You seem to have forgotten that you have a [tex]\cos\theta[/tex] in your exponential, so you must include that in your integration over [tex]d(\cos\theta)[/tex]. Note, also, that the problem suggests leaving the integral in some form for which you can't integrate any futher without numerical help (ie Mathematica, MATLAB, Maple, etc).
So far, so good:approve:
Are you sure about this?:wink:
Yes, and wouldn't [tex]F(x')[/tex] also have some dependency on [tex]\phi[/tex] and [tex]\theta[/tex], since [tex]x'=r'=\sqrt{x'^2+y'^2+z'^2}[/tex]?
Isn't...
[tex]\sum_k |a^{(k)}\rangle \langle a^{(k)}|=\textbf{1}[/tex]
...the "identity" operator?
Bill Foster said:
Isn't...
Sure, but what you've essentially done is say that
[tex]\sum_k f\left(a^{(k)}\right)|a^{(k)}\rangle \langle a^{(k)}|=f\left(a^{(k)}\right)\sum_k |a^{(k)}\rangle \langle a^{(k)}|=f\left(a^{(k)}\right)[/tex]
How can that possibly be?
