Evaluating/Solving Logarithmic expressions/equations
  • Thread starter Thread starter wvcaudill2
    Logarithmic
The discussion centers on evaluating logarithmic expressions, specifically "log base 8 of 16." Participants express confusion over the textbook's explanation, which uses the definition of logarithms to equate the expression to an exponential form, 8^x = 16. Clarification is provided that setting the expression equal to x is standard practice, as it allows for solving the equation using properties of exponents. The conversation then shifts to another logarithmic problem, where participants discuss how to manipulate logarithmic equations using properties like the product rule and the power rule. Ultimately, the discussion emphasizes understanding logarithmic definitions and properties to solve equations effectively.
wvcaudill2
Evaluate the expression "log base 8 of 16"
Don't know of any
I don't know where to begin. I have read the textbook chapter on logarithms three times over, and I am now more thoroughly confused than ever. My textbooks seems to be skipping steps and citing the "Def. of Logarithm" as the reasoning.
For the problem above, my textbook says to set the expression equal to x, and then magically gets 8^x=16. After this, it gets an answer of 4/3, without mentioning how. I assume it wants me to look at the problem and be able to see that 8^(4/3)=16, but I don't think I can do that with all problems. I am confused as to why you set the expression equal to x, and then how the expression is rearanged to get 8^x.
Can someone please walk me through this problem without skipping any steps?
Don't know of any
This isn't magic. They are using the definition of the logarithm, which says:
x = logay is equivalent to y = ax
(There are some restrictions on y and a that I have omitted.)
For your expression, you have x = log8 16, which is equivalent to 16 = 8x. There are no missing steps; the book is using the defining relationship between a log equation and the equivalent exponential equation.
It's useful to think of the log, base a, of a number as the exponent on a that produces that number. So if x is the log, base 8, of 16, then 8x = 16.
Continuing the problem requires knowledge of the laws of exponents, one of which is that (am)n = amn. 16 is a power of 2, and so is 8. Another property is that am = an ==> m = n.
You have 16 = 8x, so 24 = (23)x.
Can you finish the problem now?
Thanks, I see how to get 4/3 now.
What about this problem?
log base 6 of x = (.5 log base 6 of 9)+(.33 log base 6 of 27)
How do I get rid of the logs? Since they have the same base, can I just divide all the terms by log base 6 to cancel everything out?
Absolutely not! log6 is not a number -- it's a function
What properties of logs (any base) do you know? LIst the ones you know and we can go from there.
Well, I think this is the one applicable to this problem:
Product: log base b of mn = log base b of m + log base b of n
What do I do with the numbers in front of the logs though?
Another one is logb an = n logba
Ok, that's what I needed to solve this problem. Thanks!
Remember not to exponentiate unless you have only one log on one or both sides of the equal sign. Dunno why, but I always used to forget about that...
You can exponentiate whenever you want as long as you keep all the properties of exponentiation and logarithms straight
The difficulty in this prompts many to advise against exponentiating until exactly one log expression is on each side of the equality. But yeah, you can...
Another solution is to raise both sides to a power of 6.
6 ^ (log base 6 of x) = 6 ^ [(.5 log base 6 of 9)+(.33 log base 6 of 27)]
Since 6^x and log base 6 of x are inverse functions, then
x = [ 6 ^ (.5 log base 6 of 9) ] [ 6 ^ (.33 log base 6 of 27) ]
Using the Power Rule for Logs ..
x = [ 9 ^ 0.5 ] [ 27 ^ 0.33 ]
x = 3 x 3
x = 9
  • · Replies 17 ·
