Evaluating the Curl Using Stokes' Theorem
  • Thread starter Sai-
    Theorem
Sai-
Use Stokes' Theorem to evaluate [itex]\int\int curl \vec{F}\bullet d\vec{S}[/itex] where [itex]\vec{F}(x,y,z) = <e^{z^{2}},4z-y,8xsin(y)>[/itex] and S is the portion of the paraboloid
[itex]z = 4-x^{2}-y^{2}[/itex] above the xy plane.
Stokes Thm:[itex]\int\int curl \vec{F}\bullet d\vec{S} = \int \vec{F}\bullet d\vec{r}[/itex]
S: [itex]z = 4-x^{2}-y^{2}[/itex] above the z = 0.
C: [itex]\vec{r}(t) = <2cos(t), 2sin(t), 0>[/itex] where [itex]0\leq t\leq2\pi[/itex]
[itex]\vec{r}'(t) = <-2sin(t), 2cos(t), 0>[/itex]
[itex]\vec{F}(\vec{r}(t)) = <e^{0}, (4(0) - 2sin(t), 8(2(cos(t))sin(2cos(t))>[/itex]
[itex]\vec{F}(\vec{r}(t)) = <1, -2sin(t), 16cos(t)sin(2cos(t))>[/itex]
[itex]\int <1, -2sin(t), 16cos(t)sin(2cos(t))> \bullet <-2sin(t), 2cos(t), 0> dt[/itex] from 0 to 2pi
[itex]=\int -2sin(t)-2sin(t)2cos(t) dt[/itex] from 0 to 2pi
[itex]=0[/itex]
Sai- said:
Use Stokes' Theorem to evaluate [itex]\int\int \nabla \times \vec{F}\cdot d\vec{S}[/itex] where [itex]\vec{F}(x,y,z) = <e^{z^{2}},4z-y,8x\sin(y)>[/itex] and S is the portion of the paraboloid
Stokes Thm:[itex]\int\int \nabla \times \vec{F}\cdot d\vec{S} = \int \vec{F}\cdot d\vec{r}[/itex]
C: [itex]\vec{r}(t) = <2\cos(t), 2\sin(t), 0>[/itex] where [itex]0\leq t\leq2\pi[/itex]
[itex]\vec{r}'(t) = <-2\sin(t), 2\cos(t), 0>[/itex]
[itex]\vec{F}(\vec{r}(t)) = <e^{0}, (4(0) - 2\sin(t), 8(2(\cos(t))\sin(2\cos(t))>[/itex]
[itex]\vec{F}(\vec{r}(t)) = <1, -2\sin(t), 16\cos(t)\sin(2\cos(t))>[/itex]
[itex]\int <1, -2\sin(t), 16\cos(t)\sin(2\cos(t))> \cdot <-2\sin(t), 2\cos(t), 0> dt[/itex] from 0 to 2pi
[itex]=\int_0^{2\pi} -2\sin(t)-2\sin(t)2\cos(t) dt[/itex] [STRIKE]from 0 to 2pi[/STRIKE]
[itex]=0[/itex]
Some latex pointers. If you will put a backslash in front of any function in tex it prints in a much nicer font. Also you can use \cdot instead of \bullet and \nabla\times for curl. I have done that in my quote so you can see the difference. Also you can put the limits on the integral as I illustrate in one line above.
A problem like this should give some orientation for the surface, although with an answer of zero it doesn't matter much. Your work looks correct unless I have overlooked something.
Thank you, I will remember those hints and tips for next time!
And thanks for looking at my work, I think it is correct too; I just can't afford to miss any points on any problem, its dead week and I need all the points I can get.
