Exam III Practice Problems (liquids and pressures)
97 replies · 14K views
Alt+F4 said:
Question 25 http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa04
Okay so i got the answer to 24 which was 600. FOR 25 i am going to use this formula h = (M + m)/ (Density* A)
D= M/v
600 = M/ (2*.15) or is it (2*.25)
little m is just 20*3 = 60
Density on bottom is 1000
A = .25*2
plug that it and i am not getting the answer
Forget what i did upthere
this is what i did
the buyoant force has to balance the weight
Fb = m*9.8
(1000)(9.8)(X) = (300+60)(9.8)
X=.36
.15-.36 = .21 m which is not answer
this is what i did
Fb = m*9.8
X=.36
Two problems:
(1) Why do you think the mass of the wood is 300 kg?
(2) The "X" in your equation stands for volume displaced, not depth.
Doc Al said:
Two problems:
cause i got a density of 600
So what i did was
D= M/V
600 = M/ (2*.25) which gave me 300
Doc Al said:
Two problems:
well i was thinking since it is already at .15, whatever the number i will get will have the .15 added to it
So what i did was
D= M/V
Volume requires all three dimesions. You multiplied length by height, but what about width? (If you include units in your calculations, you'll be less likely to make this kind of error.)
Don't confuse length (or depth) with volume. Length is measured in meters; volume in cubic meters--very different.
okay so mass is 450 of log, Children are 60 KG
Total = 510 Kg
so...
Boyancy force = Total weight of people + log
(1000)(9.8)(x) = (450+60)(9.8)
ummm i am lost
Total = 510 Kg
so...
ummm i am lost
So far, so good. Realize that x = volume of the displaced water. Volume = Length*Width*Depth (length and width are given).
wow thanks, all this and its a 2 star. Geee
Sorry back again, http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa04 Question 24. I guess i did it wrong and got the right answer or this is the way to do it
So all i did was
(1000)(9.8)(.15) = (9.8)(2*.25)^2(X)
Density i got was 600 which is the answer
So all i did was
Not sure what that (2*.25)^2 is supposed to be. (But it gives the right answer! :rolleyes: )
Use the same equation as before, with volume = L*W*D:
(1000)(9.8)(L*W)(.15) = X (9.8) (L*W)(.25)
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp02 Question 17.
Thanks for your help
I think this should be it for today :)
so i was thinking of using Bernoulli Equation but i guess you would have 2 Unknows since u don't know the volume of air
so i guess you would have to use the Buyoant force equation
so what i did was
(9.8)(1.27)(687) = 8550.402
P.S how can u remb all this stuff. Are you a Prof or a teacher
so what i did was
This problem has nothing to do with Bernoulli, so you are correct in applying the Buoyant force equation.
What you found is the total mass of the balloon + cargo + hot air; now find just the mass of the hot air by subtracting out the given mass of the balloon + cargo. Then use that to find the density of the hot air. (You can assume that the given volume is the volume of the hot air.)
I can't give away all my secrets. :wink:
I lied
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp04 Question 10.
ummm Please tell me this is Bernoulli
What confuses me about these is what do i do with all these masses?
Alt+F4 said:
I lied
I'm afraid I can't tell you that it's a Bernoulli problem. It's a buoyant force problem, just like the others. To raise the ship the buoyant force must be at least enough to equal the weight of the masses: ship + ballast + air.
Note: Bernoulli problems typically involve figuring out changes in pressure or speed along a moving fluid, like water flowing through a pipe of varying diameter.
so what i did was
(1027)(9.8)(X) = (50,000+100)*9.8
How Does air play a role since i did not use the density of air
Anyways i get 48.7, when i divide that by 2 since there are 2 Ballast i get 24.4 which is answer
Alt+F4 said:
so what i did was
The density of air allows you to compute the mass of the air, which in this case is too small to worry about. A more accurate equation would be:
(1027)(9.8)(X) = (50,000+100 + (1.25*X))*9.8
But that 1.25*X term can be neglected compared to 1027*X. (Note that we are also ignoring the volume of the ship--we assume that it's tiny compared to the ballast tanks. Although it looks big in the drawing.)
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp05 Question 15. I understand it but for some reason it is a 2 star so i just wana make sure i got it for the right reason.
So i knew it was between B and C since it starts from Zero, and velocity must be positive since it said in the problem it is traveling whith a (+) velocity of 11.1 m /s
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp04 Question 19 and 21. Same question word for word yet 19.B and 21 is C. Am i missing something?>
Not sure I understand your reasoning, but you probably got the correct answer. Explain your thinking when you say "i knew it was between B and C since it starts from Zero?" What starts from zero? (Surely not the velocity.)
the time started from zero
They didn't do a good job in wording the question. I suspect that for questions 20 and 21 you are to assume that the plug has been removed so that fluid can flow through the pipe. (Otherwise 20 makes no sense and 21 would be the same as 19, as you realize.)
That's certainly true, but give your complete reasoning for the answer you think is correct if you'd like me to confirm your thinking.
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp00 Question 10.
I assumed it would b Lead > Iron
Since (higher Density)(9.8)(Same Volume) > ( Lower Density)(9.8)( Same volume)
but then they turn out to be equal so i think the density to what we plug in is the water density instead of Iron or Lead since the objects are floating in water. Is this correcT?
Yes. The buoyant force equals the weight of the displaced fluid, so it's the density of water that is used.
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa05 question 10
So what i did was
pgy = pgy
(1000)(9.8)(.3) = (.6)(x)(9.8)
Density of 500 but answer is 666
Edit:
Okay i think this is it
(1000)(9.8)(.7-.3) = (X)(9.8)(.6)
X = 666.67
Is this the correct way
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa05 Question 11. I know i am doing this right
So convert 90 cycles per 1 minute into cycles per second which is 1.5 cycles per sec
T= 2pi/ omega
1.5 = 2pie/ omega
omega = 4.1887
it is a pendulum so
omega^2 = G/L
(4.18879)^2 = 9.8/L
L = .55meters
I only get the answer when i do 60/90 which is 0.66 cycels per sec which makes no sense
X = 666.67
That's right. The key here is that the pressure at the interface must be the same on both sides. So the .7-.3= .4m column of water must balance the .6m column of other fluid.
T= 2pi/ omega
1.5 = 2pie/ omega
omega = 4.1887
it is a pendulum so
omega^2 = G/L
(4.18879)^2 = 9.8/L
L = .55meters
You are confusing frequency (cycles per second) with period (seconds). To convert frequency to omega (angular frequency, measured in radians per second), multiply by the number of radians per cycle (which you should know).
