Existence of fringe effects with a capacitor
The discussion centers on proving the existence of fringe effects in the electric field at the edges of a plate capacitor using Maxwell's laws. Participants highlight that, unlike ideal capacitors, real capacitors exhibit fringe effects due to the continuity of the electric field. A suggested approach involves applying Gauss's law by considering a surface that encloses charge and extends to infinity, demonstrating that electric flux must exit through the sides of the surface. This method effectively illustrates the presence of fringe effects outside the capacitor plates.
  • Understanding of Maxwell's laws
  • Familiarity with Gauss's law
  • Knowledge of electric fields and dipoles
  • Concept of electric flux
  • Study the application of Gauss's law in electrostatics
  • Explore the concept of electric dipoles and their field lines
  • Research fringe effects in capacitors and their implications
  • Learn about boundary conditions in electric fields
Physics students, electrical engineers, and anyone studying electrostatics or capacitor behavior in real-world applications.
wimvd
I was surfing some old exam questions and I found a nasty one... They asked to prove the existence of fringe effects of the electric field at the edges of a plate capacitor, using Maxwell's laws.
In class we always assumed the ideal capacitor without fringe effects so I'm having some kind of mental block. I have no clue what surface or integration path to choose.
The only idea I have is that from a distance the capacitor should look like an electric dipole and show the same field lines as the electric dipole, and thus there should be fringe effects. But that's not really USING Maxwell's laws is it? :/
Any chance someone can put me on the right path/surface?
Thanks.
Probably the easiest argument to make is that the electric field in boundary-less, charge-less, current-less areas must be continuous. Thus, if you move from between the plates to outside the plates, your electric field cannot drop from a finite value to a zero value instantaneously, so there must be some electric field outside the plates.
A more direct application would be to consider a surface that passes through the metal (and encloses some charge), and extends off to infinity. Since the electrix flux through the top and bottom sides of the box must be zero (one is in a metal, one is at infinity), using Gauss's law, there must be some flux going out the sides.
Perfect! Thanks! :)
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 103 ·
