Expansion of Cos(x) in Hermite polynomials
The discussion revolves around finding the coefficients of the expansion of the function Cos(x) in terms of Hermite polynomials. The original poster presents a challenge due to the infinite degree of the Taylor series for Cos(x) compared to the finite degree of the Hermite polynomials.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use orthogonality properties of Hermite polynomials to derive coefficients but encounters difficulties with the resulting integrals. Some participants question the validity of the original poster's method and provide alternative evaluations for the coefficients.
Participants are actively engaging with the problem, with some providing partial results for the coefficients. There is a recognition of differing methods and results, particularly regarding the evaluation of integrals. The discussion is ongoing, with no clear consensus yet on the final values of the coefficients.
Participants note that the problem is set in an exam context, which imposes constraints on the methods that can be used, particularly the inability to use computational tools.
Dansuer
[/itex]
Find the first three coeficents c_n of the expansion of Cos(x) in Hermite Polynomials.
The first three Hermite Polinomials are:
[itex]H_0(x) = 1[/itex]
[itex]H_1(x) = 2x[/itex]
[itex]H_0(x) = 4x^2-2[/itex]
I know how to solve a similar problem where the function is a polynomial of finite degree, say x^3. Using the fact that H_n(x) is a polinomial of degree n, i set all the coeficent after c_3 equal to zero and equate the terms with equal degree. I find a system of linear equations and i solve it.
In this case however the taylor series of Cos(x) is a polinomial of infinite degree. I can't apply this method.
I then try to use the orthogonality of the Hermite polynomials
[itex]\int^{∞}_{-∞}e^{-x^2}H_n(x)H_m(x)dx = \sqrt{\pi}2^nn!\delta_{nm}[/itex]
From the orthogonality i find the coeficents to be
[itex]c_0 = \frac{1}{\sqrt{\pi}2^nn!}\int^{∞}_{-∞}e^{-x^2} Cos(x) dx[/itex]
[itex]c_1 = \frac{1}{\sqrt{\pi}2^nn!}\int^{∞}_{-∞}e^{-x^2} 2xCos(x) dx[/itex]
[itex]c_2 = \frac{1}{\sqrt{\pi}2^nn!}\int^{∞}_{-∞}e^{-x^2} (4x^2-2)Cos(x) dx[/itex]
Which are three hard integrals i haven't been able to solve. I can't use computer methods as I'm suppose to solve this in an exam with pen and paper. I'm stuck.
Thanks to anyone who takes a look at this.:-p
I don't think you can do that as the higher hermite polinomials are not zero.
I've figured the first and second integrals and they are
[itex]c_0 = \frac{1}{\sqrt{e}^{4}}[/itex]
[itex]c_1 =0[/itex]
c_0 differs from your method.
i still need to find the last integral though.
[itex]c_1 =0[/itex]
For ##c_2##, you have two integrals.
$$4\int_{-\infty}^{\infty} x^2e^{-x^2}\cos(x)\,dx-2\int_{-\infty}^{\infty} e^{-x^2}\cos(x)\,dx$$
Since you already evaluated ##c_0##, you know the value of second integral. To evaluate the first integral, consider the following definite integral:
$$I(a)=\int_{-\infty}^{\infty} e^{-a^2x^2}\cos(x)\,dx=\frac{\sqrt{\pi}}{a}e^{-1/(4a^2)}\,\,\,\,\,\,\,\,(*)$$
You should be able to prove the above result in the same way you evaluated ##c_0##.
Differentiate both the sides of ##(*)## with respect to ##a## to obtain:
$$\int_{-\infty}^{\infty}-2ax^2e^{-a^2x^2}\cos(x)\,dx=\sqrt{\pi}\frac{e^{-1/(4a^2)}(1-2a^2)}{2a^4} $$
Substitute ##a=1## and you should be able to obtain the answer after some rearrangement of the above expression.
Thanks a lot!:biggrin:
Glad to help! :smile:
  • · Replies 105 ·
11K
  • · Replies 22 ·
