Expansion of the Universe
The discussion revolves around the expansion of the universe, particularly focusing on the implications of general relativity, Hubble's Law, and the role of dark energy in the accelerating expansion. Participants explore theoretical and observational aspects of cosmic expansion, including gravitational effects and the historical context of scientific discoveries.
  • Some participants assert that Einstein's equations indicate an expanding universe, with later observations suggesting that this expansion is accelerating, potentially due to dark energy.
  • Others argue that without dark energy, a universe with mass must decelerate, as gravitational attraction cannot be repulsive, and thus acceleration requires a repulsive force like dark energy.
  • One participant references the Friedmann Equations to claim that a universe containing only matter and radiation would experience decelerating expansion.
  • Another participant discusses Hubble's Law, noting its empirical nature and questioning the robustness of Hubble's initial conclusions based on limited data.
  • Some participants express differing views on the current state of the universe's expansion, with one suggesting that the deceleration is slowing rather than the rate of expansion increasing.
  • A later reply clarifies the distinction between the rate of expansion and acceleration, indicating that current observations suggest a positive acceleration if dark energy is dominant.
Participants express multiple competing views regarding the role of dark energy and the nature of the universe's expansion. There is no consensus on whether the universe is currently expanding at an accelerating rate or if the rate of expansion is decreasing.
Some claims depend on interpretations of general relativity and the Friedmann Equations, while others rely on historical context regarding Hubble's Law. The discussion reflects varying assumptions about gravitational effects and the nature of cosmic expansion.
petercl14
TL;DR
accelerating expansion of the universe
Einstein's equations in general relativity indicate that the universe is expanding. Einstein himself believed that the universe should be stable so he introduced a correction to his equations which made for a static universe. He later admitted that was his biggest blunder. Hubble proved by observation that the universe was indeed expanding.
Latest observations are that the universe is expanding at an accelerating pace. Faster than in the past. Scientists are now trying to introduce a new phenomenon called dark energy to account for this.
As the universe expands galaxies become further apart. There is less gravitational attraction between them. Thus the universe will expand at an accelerating rate. There is no need to introduce another non entity like dark matter and call it dark energy.
Space news on Phys.org
See, the first two sentences are fine. But the third doesn't follow - not without dark energy. Without dark energy a universe with any amount of mass in it must always decelerate, much like a ball thrown out of a gravity well must always decelerate even as the gravitational potential monotonically decreases. I.e. there is always some attraction, invariably acting to slow the galaxies down - because gravity can't be repulsive.
To get acceleration you need something repulsive to take over once the mass density goes down sufficiently. That's what dark energy does.
No, this is not correct. As can easily be seen from the Friedmann Equations, which are just the Einstein Field Equations for the case of a homogeneous, isotropic, expanding universe, a universe that only contains matter and radiation, with no dark energy, will have decelerating expansion.
I did a google search for:
The Implications of Hubble's Law: An Expanding Universe
e-education.psu.edu
Here is the opening paragraph:
"Like Kepler's Laws, Hubble's Law is an empirical law. Hubble discovered a relationship between two measurable properties of galaxies: their velocities and their distances. Given this relationship, though, it naturally leads to several questions. These questions are:
  • What is the cause of this relationship?
  • Why should more distant galaxies have larger velocities?"
As a layman, I found the article's information to be informative, thought provoking, and relevant.
(Mods - if my post has violated any rules, I assure you that I am posting in good faith, and I ask for your understanding.)
e-education.psu.edu
One difference between Kepler and Hubble is that Kepler took 20 years to work through an enormous amount of data on planetary motion before finally proving that the orbits were elliptical relative to the Sun. Hubble, on the other hand, took a huge guess based on a small sample of inconclusive data. The data that really confirms Hubble's law only came out years afterwards. But, by then, his was the name on it. The two sides of experimental science and gaining immortality!
petercl14 said:
TL;DR Summary: accelerating expansion of the universe
Your argument fails for the same reason that the following argument fails:
"As a rocket ascends, it moves away from Earth. There will be less gravitational attraction between Earth and the rocket. Thus, the rocket will move away from Earth at an accelerating rate and will not require additional fuel expenditure."
I believe the current effect is that the deceleration of the expansion is slowing, not that the rate of expansion is increasing. A bit like gradually applying less force on the brakes when stopping your car. You decelerate hard at first, then less and less over time. The current rate of expansion is less than in the past.
@PeterDonis is that correct?
If by "the rate of expansion" we mean ##\dot{a}##, i.e., the rate of change of the scale factor with respect to the proper time of comoving observers, and by "acceleration" we mean ##\ddot{a}##, the rate of change of ##\dot{a}## with respect to that same proper time, then the acceleration now is positive, ##\ddot{a} > 0##, and has been so for a few billion years. This is what we would expect if dark energy dominates the dynamics, i.e., if dark energy density is larger than all of the others combined (IIRC it's about twice as large now as all the others combined).
The misconception in the OP has been corrected. Thread closed.
PeterDonis said:
AFAIK, if by "the rate of expansion" we mean ##\dot{a}##, i.e., the rate of change of the scale factor with respect to the proper time of comoving observers, and by "acceleration" we mean ##\ddot{a}##, the rate of change of ##\dot{a}## with respect to that same proper time, then the acceleration now is positive, ##\ddot{a} > 0##, and has been so for a few billion years. This is what we would expect if dark energy dominates the dynamics, i.e., if dark energy density is larger than all of the others combined (IIRC it's about twice as large now as all the others combined).
Ah, well nevermind then. I thought I had read otherwise.
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 20 ·
