Expectation of Normal Distribution
The discussion revolves around calculating the expected values of a function involving a standard normal random variable, specifically focusing on the moments E[Z^3] and E[Z^4]. The original poster expresses difficulty in progressing with the integration required for these calculations.
  • Participants discuss the use of integration by parts to compute expected values and question the application of this method to higher powers of Z. There are inquiries about the definitions of functions involved, such as the probability density function (pdf) and cumulative distribution function (cdf) of the normal distribution.
Participants are actively engaging with the problem, sharing their attempts and seeking clarification on specific steps in the integration process. Some guidance has been offered regarding the use of integration by parts, but there is no explicit consensus on the approach or solution yet.
The original poster indicates a struggle with the integration process and expresses uncertainty about the outcome of their calculations. There is a mention of potential constraints related to the lack of symbols in their posts, which may affect clarity in communication.
MattFox
Let Y = a + bZ + cZ2 where Z (0,1) is a standard normal random variable.
(i) Compute E[Y], E[Z], E[YZ], E[Y^2] and E[Z^2].
HINT: You will need to determine E[Z^r], r = 1, 2, 3, 4. When r = 1, 2 you should
use known results. Integration by parts will help when r = 3, 4.
I am struggling with the part of the question involving E[Z^3] and E[Z^4]. Clearly E[Z]=0 and E[Z^2]=1 but I do not no where to proceed when computing higher powers of Z. Any help would be greatly appreciated.
Thanks
Expected value of a function g of z is E[g(z)] = [itex]\int_{-\infty}^{+\infty}g(z)f(z)dz[/itex] where f is the pdf of z.
So am I right in thinking I let g(z) = z^3 and f(z)= 1/(sigma * sqrt2pi) ... and then use integration by parts?
That should be it.
I'm not really getting anywhere with the integration by parts. Is there any hint you could offer or show me a step I could be missing out?
Can you post what you have so far?
Ok so,
INT u dv = uv - INT v du
Then i let u = Z^3 and dv = the pdf of the normal dist.
Im lost when it comes to integrating the pdf and I'm not sure how it will condense down to a manageable solution. Sorry about the lack of symbols, I'm not sure how to properly upload images yet.
If dv = the pdf of the normal dist., then what is v?
(If dv = f(z) and v = F(z), what is F?)
F(z) is the cdf of the normal distribution.
So E(Z^3) = Z^3 * F(Z) - INT 3Z^2 * F(Z).
Do i then need to apply integration by parts again? I'm sorry if I'm asking too many questions I just really don't understand what I'm trying to achieve as a solution.
Or more accurately, what form the solution will take i.e an integer, function of Z...
u = Z^3 and dv = f(z)dz ===> v = F(z)
E(Z^3) = INT u dv = [uv] - INT v du = [Z^3 * F(Z)] - INT F(Z) 3Z^2 dZ, where each of the [uv] expression and the last INT are evaluated over (-infinity, +infinity).
E.g., [uv] = u(+infinity)v(+infinity) - u(-infinity)v(-infinity) ... but (infinity)^3 is not a real number, so something's amiss. See http://en.wikipedia.org/wiki/Integration_by_parts
