Expectation of Normal Distribution
11 replies · 24K views
MattFox
Let Y = a + bZ + cZ2 where Z (0,1) is a standard normal random variable.
(i) Compute E[Y], E[Z], E[YZ], E[Y^2] and E[Z^2].
HINT: You will need to determine E[Z^r], r = 1, 2, 3, 4. When r = 1, 2 you should
use known results. Integration by parts will help when r = 3, 4.
I am struggling with the part of the question involving E[Z^3] and E[Z^4]. Clearly E[Z]=0 and E[Z^2]=1 but I do not no where to proceed when computing higher powers of Z. Any help would be greatly appreciated.
Thanks
Expected value of a function g of z is E[g(z)] = [itex]\int_{-\infty}^{+\infty}g(z)f(z)dz[/itex] where f is the pdf of z.
So am I right in thinking I let g(z) = z^3 and f(z)= 1/(sigma * sqrt2pi) ... and then use integration by parts?
I'm not really getting anywhere with the integration by parts. Is there any hint you could offer or show me a step I could be missing out?
Ok so,
INT u dv = uv - INT v du
Then i let u = Z^3 and dv = the pdf of the normal dist.
Im lost when it comes to integrating the pdf and I'm not sure how it will condense down to a manageable solution. Sorry about the lack of symbols, I'm not sure how to properly upload images yet.
If dv = the pdf of the normal dist., then what is v?
(If dv = f(z) and v = F(z), what is F?)
F(z) is the cdf of the normal distribution.
So E(Z^3) = Z^3 * F(Z) - INT 3Z^2 * F(Z).
Do i then need to apply integration by parts again? I'm sorry if I'm asking too many questions I just really don't understand what I'm trying to achieve as a solution.
Or more accurately, what form the solution will take i.e an integer, function of Z...
u = Z^3 and dv = f(z)dz ===> v = F(z)
E(Z^3) = INT u dv = [uv] - INT v du = [Z^3 * F(Z)] - INT F(Z) 3Z^2 dZ, where each of the [uv] expression and the last INT are evaluated over (-infinity, +infinity).
E.g., [uv] = u(+infinity)v(+infinity) - u(-infinity)v(-infinity) ... but (infinity)^3 is not a real number, so something's amiss. See http://en.wikipedia.org/wiki/Integration_by_parts
