What Does <x^2> Represent in Quantum Mechanics?
The discussion centers on the interpretation of the expectation values and in quantum mechanics, particularly in the context of a particle in an infinite square well of length L. The classical expectation value is calculated as L/2, while yields L^2/3, contrasting with the quantum result of L^2/3 - L^3/(2π^2). The correspondence principle is invoked to explain the convergence of quantum and classical results as the quantum number n approaches infinity, revealing that both expectation values align with classical predictions in this limit.
  • Understanding of expectation values in quantum mechanics
  • Familiarity with the infinite square well model
  • Basic knowledge of probability density functions
  • Concept of the correspondence principle in quantum mechanics
  • Study the derivation of expectation values in quantum mechanics using wave functions
  • Explore the implications of the correspondence principle in various quantum systems
  • Learn about the significance of the quantum number n in quantum mechanics
  • Investigate the differences between classical and quantum probability distributions
Students and educators in physics, particularly those focusing on quantum mechanics, as well as researchers interested in the foundational concepts of expectation values and the correspondence principle.
teroenza
1. What is <x^{2}>, in terms of position and expectation values.
2. How can I use the correspondence principal to explain the quantum vs classical results (below).
My textbook (Serway, Modern Physics) uses <x> as the expectation value, meaning the average position of a particle. It also uses <x^{2}> in one example, and wants me to calculate it. I have calculated it by using the formula for <x>, but have no idea what it represents. The book does not define it, and I can't find it elsewhere.
The problem is to compare my calculated classical <x> and <x^{2}> values vs the books example calculating them for a quantum situation (particle in infinite square well of length L).
<x> = \intx (1/L)dx from 0 to L
<x^{2}> = = \intx^{} (1/L)dx from 0 to L
The probability density (classical) is given as 1/L.
My classical <x> agrees with that of the book's quantum = L/2
My classical <x^{2}> is L^{2}/3 while the book's quantum value is L^{2}/3 -L^{3}/(2 pi^{2}).
I am also to use the correspondence principal to discuss the findings, but I cannot see how the quantum value would be altered (no n factor to increase) as the quantum world approaches the macro.
Thank you for your time.
The expectation value of a function g(X) of a continuous random variable X is given by
\langle g(x)\rangle = \int g(x) f(x)\,dxwhere f(x) is the probability density function for X.
For the classical case, you have f(x)=1/L, so
\begin{align*}
\langle x \rangle &= \int_0^L x \frac{1}{L}\,dx \\
\langle x^2 \rangle &= \int_0^L x^2 \frac{1}{L}\,dx
\end{align*}
The only difference for the quantum case is that you now have f(x)=|ψ(x)|2.
O.k. thank you. I used the equation with x^{2} to arrive at my answer for the <x^{2}> part of the question. So if <x> is the average position, <x^{2}> is just the average of the position squared? I don't seem to understand the reason for the squaring. I assume <x^{2}> means the same thing for the classical and quantum, like <x> = average position, in both.
Yes, you got it. As for the reason why you'd calculate <x2>, it's simply because the math calls for it. For example, the characteristic width of the wave function is \Delta x = \sqrt{\langle (x-\langle x \rangle)^2 \rangle} = \sqrt{\langle x^2 \rangle - \langle x \rangle^2}. In plain old probability and statistics, this is how you'd calculate the standard deviation of a random distribution.
Great, thanks for the help.
I am still puzzled as to how I can use these results to "discuss" Bohr's correspondence principal. I see the classical and quantum results agree for the <x> value, which makes sense, because in in infinite well they are both forever confined within. However, I cannot explain the discrepancy in the <x^{2}>value. There is no "n" quantum number for me to increase ad thus see what happens as the quantum scale approaches the classical.
Did your book calculate the expectation value for a particular value of n? If not, it's a typo. There should be an n in the answer.
You are correct, the books quantum expression was for the ground state (n=1).
There was an n in every answer, just hidden as n=1, in the denominator. So as n\rightarrowinfinity, both quantum terms go to zero. Thus predicting a zero average position and average position squared. Does this mean the particle is now localized at the origin?
That's not correct. In the limit as n goes to infinity, the quantum mechanical result should go to the classical result.
I made a mistake in following the n through the books calculations. You are correct, the 2nd term drops out (in the <x^2>, so that it approaches macroscopic reality as n gets large.
