Experiment: Measuring the focal length of a converging lens
The discussion revolves around an experimental setup for measuring the focal length of a converging lens using an object grid, light source, and screen. Participants are exploring the relationship between object and image distances, as well as the expected accuracy of their measurements.
  • The original poster attempts to set up the experiment but encounters issues with visibility of the object grid and discrepancies in focal length measurements. Participants suggest adjustments to the setup and question the clarity of the images produced.
The discussion is ongoing, with participants providing suggestions for adjusting the experimental setup. There is an exploration of the reasons behind the observed phenomena, but no consensus has been reached regarding the accuracy of the measurements or the expected focal length.
Participants are working within the constraints of the experimental setup and the expected outcomes based on theoretical principles. There is an emphasis on the accuracy of measurements and the interpretation of results, with some assumptions about the behavior of light and lenses being questioned.
Taniaz
You are required to set up a light source, an object grid, a converging lens and a screen so that a quantitative investigation of object and image distances can be performed. Tabulate corresponding object and image distances (p and p' respectively). Also tabulate values of 1/p, 1/p', p+p' and pp'.
Theory suggests that 1/p + 1/p' = 1/f. Graph (i) p' versus p, (ii) 1/p' versus 1/p, (iii) pp' versus p+p'. Explain the shape of each graph. Determine its value in each case. Which method do you think its most accurate?
State, with reasons, the level of accuracy expected from each of your measurements and hence give a statement of how accurate you expect from each of your measurements and hence give a statement of how accurate you expect your value of f to be in each case.
I set up the experiment as shown in the pictures. I placed the object grid in front of the light source, followed by a plano convex lens (f=30 cm) followed by the screen. The problem with the object grid, I don't see an image of the object grid but of an inverted filament instead (not clear in the diagram). I then removed the object grid and I still saw an inverted image of the filament. Why am I not seeing the object grid? Everything is aligned. I only see the object grid very clearly when it's really close to the source after that it disappears and a very clear image of the filament appears.
Another issue is that when I measure the object distance on the meter ruler and and subtract it from the image distance which I also read from the meter ruler, I don't get the focal length actually mentioned on the lens pack. The focal length on the pack is 30 cm and I get a difference of 85 +/- 5.
Try placing the object grid as close to the light source as you can; the grid is your object, and the source creates the rays you are trying to direct into your lens.
Hope this helps!
- Strelkov
Hi Strelkov,
Thanks for your reply. I tried doing that too, as I moved the lens further away, the object grid would turn into this blur circle of light and then suddenly, after further movement, a very clear, inverted image of the filament would show up. Quite strange.
Exactly!
Since you only have one lens, the resulting image will be inverted(recall ray trace diagrams). Once the image is clear and inverted, you have found the image; now use the lensmaker's formula to confirm your focal length.
- Strelkov
Yes I am aware that it will be inverted but my object is the grid and not the filament of the light source? And I don't get the focal length to be the same as what it said on its packaging?
Try this:
Position the lens where you get
Taniaz said:
...a very clear, inverted image of the filament...
Now move the light farther away from the lens and put the grid where the light used to be.
Ok I'll try that but why can't I seem to get it with the light source present?
I've attached a video of what I get. It's so clear.
Can't seem to upload it :/
  • · Replies 20 ·
  • · Replies 19 ·
