Experiment to show resistance is proportional to wire length
9 replies · 2K views
Drizzy
My task is to plan and carry out experiments which show that the resistance of a conductor is proportional to the conductor's length. I have access to the following equipment: http://imgur.com/a/GuqUX
Amperemeter, voltmeter, electricity, ruler som other werid things and chromiumnickel
I am guessing that I need these equations:
U = RI.
R = ρ
Where should I start? First off, do I have the right equations? And secondly, how long should the wires be? 30 cm, 60 cm and 90 cm? Is that good?
U = RI.
R = ρ
Your second equation is missing something. What are the units of resistance on the left hand side? What are the units of resistivity on the right hand side? So what is missing? :smile:
oops somehow it was cut off :/
R = rho l/A
I am guessing that I will have to calculate R, but should U or I be constant?
Do I really need the second equation? I thought maybe I could calculate R and then divide it by the length of the resistor and then make a graph or something. Which method is the best?
Drizzy said:
U = RI.
Correct.
Drizzy said:
R = rho l/A
Drizzy said:
I am guessing that I will have to calculate R, but should U och I be constant?
I'm used to writing V = I * R, rather than using U for voltage, but you can use U if that's what your textbooks use. Resistance is independent of the test voltage, as long as you use regular voltages and not some high voltage that can cause arcing.
So show us what you have so far for a lab experimental procedure... :smile:
In reality, you only need ti use the resistance measurement scale on your Volt-Ampere-Ohm meter. When measuring resistance the meter's internal battery supplies the necessary fixed voltage and while attaching the different lengths of one of selected wires directly between the + and - poles on the meter, the meter scale will give you the resistance value for each.
Based upon what I have said and the V=I*R equation, what do you think the meter is actually measuring to give you the resistance values on its resistance scale?
To get the best resistance vs. length differentials for your measurements, I suggest you test the same length of each of the type of wire you have to find the one that has the highest resistance for that length; and then use that type of wire for your resistance vs. length testing.
You have to select the correct resistance scale on the meter for your testing and the best way to do that is to start with the highest value setting and then keep reducing it until you get a good range for your test.
I have no idea.. we have literally just started kearning about this and our teacher gave us this assignment without any bakground information. And it is due tomorrow :(
I have one qustion, some people in my class are going to use the second equation that I wrote in my first post but I Think that it is enough if I calculate R and then just have that on the y-axis and the length of the wire on the x axis. And K is going to be constant,
