Explaining Toroidal Transformers & Their Self-Shielding Properties
  • Thread starter Thread starter dot
    Transformers
Toroidal transformers exhibit self-shielding properties, resulting in a near-zero external magnetic field, with most magnetic flux contained within the core. However, threading a conductor through the center of the toroid creates a one-turn secondary that can experience a significant current, suggesting that the loop interacts with the primary coil's magnetic field. This phenomenon raises questions about how the wire, located in a near-zero field region, can generate current. The explanation lies in Faraday's law, which states that the oscillating magnetic field induces an electric field in the wire, leading to current flow. The discussion highlights a common misunderstanding regarding the behavior of electric and magnetic fields in toroidal transformers.
dot
This question relates to 50Hz power toroidal transformers.
Toroidal transformers are well known for their self shielding properties and consequently have a near-zero external field. Most of the magnetic flux lies within the core.
Yet if one where to thread a good conductor through the centre of the toroid and connect the ends to form a loop, thus creating a one-turn secondary, one would in practice cause a short circuit and a very large current would flow (limited by the resistance of the loop).
This seems to imply that the loop is experiencing most of the field created by the primary coil. How can this be explained when the wire itself lies completely in a near-zero field region? Seems spooky to me. This phenomenon is not restricted to toroidal transformers but is at the heart of every electrical machine, just that in a toroidal transformer it becomes plain that current theories and textbooks are missing something big time. The standard answer would be that the emf generated in the secondary depends on the amount of flux “linking” the primary and secondary and in this case all of the flux plainly passes through the area enclosed by the secondary circuit. I just cannot see how this “explanation” explains anything. How do the electrons in the wire feel the primary magnetic field?
Maybe I don't understand your setup here, but why would "...wire itself lies completely in a near-zero field region..." when a part of it is threading through the center of the solenoid where the field is the largest? One could easily think of this region as the "emf source" for the secondary to cause current to flow.
Zz.
There is no B field at the wire, but there is an electric field.
The oscillating magnetic field in the toroid produces an electric field in the wire.
The integral of this field around the circle equals the rate of change of the magnetic flux.
That is Faraday's law.
To clarify
By centre of the toroid I mean not the core of the toroid, but the empty space of the "window in the doughnut" or the hole in a "Polo" mint. This space is also empty of any field as far as I know at least in an ideal toroidal transformer.
The E field is in that "empty space".
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
