Exponential Function: Understanding and Solving Problems
schan11
Help! exponential function
Please look at the attachment for the question!
Thank you for your help
An exponential function is a function f(x)=ax, where a is the ratio between entries. Since you have a bunch of data, divide between entries to find the ratio, a. Then average them to get the average ratio, and use this average ratio to find the missing values.
But how do you work out the function?
Let's take the first two entries as an example.
On day 21/5, we have 3 cases of H1N1. On day 22/5, we have 7 cases of H1N1.
What's 7/3? 2.333.
On day 22/5, we have 7 cases of H1N1. On day 23/5, we have 12 cases of H1N1.
What's 12/7? 1.714.
Hopefully by now you've noticed that these are the values in the third column.
It might be instructive to plot the raw data on semilog graph paper. (Search on google, and print out a sheet of it.) The curve of best fit should be a straight line. Measure its slope. From this you can work out the equation you seek. This should support the figures in the right-most column of your data. This exercise amounts to graphically taking an average of the numbers in the right column, and, if it hadn't already been done, would save calculating those numbers.
Even after several responses, there is no attempt at all by the original poster to work the problem himself. Thread closed.
