Solving Exponential Growth Homework: Find Water to Eliminate 50% Salt
  • Thread starter Thread starter lovemake1
    Exponential Growth
The discussion focuses on solving a differential equation related to a tank where water is pumped in to reduce the salt concentration by 50%. The equation ds/dx = -S/V, with V set at 10,000 gallons, leads to the integration of ln(S) = -x/10,000 + C. Participants clarify that V is a constant and emphasize the importance of correctly interpreting variables in the context of differential equations. The solution involves finding S(x) and determining the amount of water needed to achieve the desired salt reduction.
  • Understanding of differential equations
  • Familiarity with integration techniques
  • Knowledge of exponential functions and their properties
  • Basic concepts of saltwater solutions and concentration
  • Study the method of separation of variables in differential equations
  • Learn how to apply integration to solve real-world problems
  • Explore the concept of half-life in the context of salt concentration
  • Investigate the implications of constant volume systems in fluid dynamics
Students in differential equations courses, educators teaching mathematical modeling, and anyone interested in applied mathematics related to fluid dynamics and concentration problems.
lovemake1
Water is pumped into a tank. Volume V, is kept constant by continuos flow. The amount of salt S, depends on the amount of water that ahs been pumped in, call it X.
ds/dx = -S/V
Find the amount of water needed to eliminate 50% of the salt. Take v AS 10,000 gallons
We know that volume V is kept constant by continuos flow. d/dv ?
im througly confused...
I understand that exponential growth has the traditional formula: Ce^kt
but how can we ues it with this question?
helps appreciated.
ds/dx = -S/V
So am I! There is no differentiation with respect to V (please do not use both small and capital letters to mean the same thing). V is a constant- replace it with the 10000 you are given.
helps appreciated.
I take it this is a "differential equations" course. You would be expected to recognize that you can write the original equation as
\frac{dS}{S}= -\frac{dx}{10000}
and integrate:
ln(S)= -\frac{x}{10000}+ C
so that
S(x)= e^C e^{-\frac{x}{10000}}= C&#039; e^{-\frac{x}{V}[/itex]<br /> where C&amp;#039;= e^C. That is the &quot;Ce^{kt}&quot; you have, except that your variable is x, the amount of water that has flowed through, not time.<br /> <br /> Now solve the equation S(x)= (1/2)S(0).
Ah I see the light !
But the line after "so that",
Shouldn't it be e^lns = e^-x/v + c ?
just confused to what C is
  • · Replies 16 ·
15K
