Exponents and exponential functions
The discussion focuses on solving three exponential equations. The first equation, 5^{1-2x} = 1/5, leads to confusion about the exponent's sign, with the correct interpretation being that 1/5 equals 5^{-1}. The second equation, 8^{x^2 - 2x} = 1/2, requires recognizing that 8 can be expressed as 2^3, leading to a quadratic equation. The third equation, e^{x^2} = (e^{3x})(1/e^2), simplifies to e^{x^2} = e^{3x-2}, resulting in another quadratic equation. Overall, the conversation emphasizes the importance of understanding the laws of exponents and correctly setting up equations for solving.
carbz
Please note, there are more questions than what I'm going to give, in total I'll be giving 3. I hope to use the information with the others.
1)
Solve the equation:
5^{1-2x} = \frac{1}{5}
None
I was thinking that to make live easier, to put the entire fraction up to the first power. From there, I would use algebra in the sense of:
1-2x=1
-2x=0
To get x = 0. But, that doesn't seem to be possible, since the exponent must turn out to be negative.
2)
Solve the Equation:
8^{x^{2} - 2x}} = \frac{1}{2}
None
For this one, I was thinking of setting the fraction equal to 1, then factoring that out to get two answers:
x^2 - 2x = 1 x^2 - 2x - 1 = 0
But, then I'm stuck there.
3)
Solve the equation:
e^{x^2} = (e^{3x})(\frac{1}{e^2})
None
I'm completely clueless on this one.
1)
Solve the equation:
None
Actually a very relevant equation, or, more correctly, statement, would be "if ax= ay then x= y" (the exponential functions are "one-to-one").
1-2x=1
-2x=0
\frac{1}{5}= 5^{-1} not 51
2)
Solve the Equation:
None
8= 23 so 8^{x^2- 2x}= 2^{3(x^2- 2x)}
3)
Solve the equation:
None
Learn the "laws of exponents": (ax)y= axy (used in 2 above) and axay[/sup]= ax+y.
Here, e^{3x}(\frac{1}{e^2}= (e^{3x})(e^{-x})= e^{3x-x}= e^{2x}. Your equation is e^{x^2}= e^{x} so x2= x.
All right. For the first one, I see where you went from there. I got the answer to that to be x=1.
Ok, so with the exponents, that would be 3(x^2 - 2x) = 1. Then, factoring out an x would make it: 3x(x-2) =1 . Dividing it would cause the equation to look like: x-2 = \frac{1}{3x} Then -2 = \frac{-2}{3x} then -6x = -2 then finally I get x = \frac{1}{3}. Is that correct?
HallsofIvy said:
Learn the "laws of exponents": (ax)y= axy (used in 2 above) and axay= ax+y.
Ok, since that is so, the answer could only be either 0 or 1, since both when squared equal what it orginally was.
\frac{1}{2}=2^{-1} not 21
This is a quadratic equation, and so will have two solutions. In solving it, you should put the equation in the familliar form, and use the quadratic formula:
x=\frac{-b\pm \sqrt{b^2-4ac}}{2a}. In particular, you cannot divide by x, since you do not know it's value (it could be zero.)
Actually, I think HallsofIvy carried a typo through the below calculation:
Here, e^{3x}(\frac{1}{e^2})= (e^{3x})(e^{-x})= e^{3x-x}= e^{2x}. Your equation is e^{x^2}= e^{x} so x2= x.
It should read:
e^{3x}(\frac{1}{e^2})= (e^{3x})(e^{-2})= e^{3x-2} which gives your equation e^{x^2}=e^{3x-2} giving x^2=3x-2. This can again be solved as a quadratic equation.
How did you manage to go from x-2= \frac{1}{3x}to -2= \frac{-2}{3x}? 3(x^2- 2x)= 1 is a quadratic equation, as Cristo says. In "standard form" it is 3x^2- 6x- 1= 0.<br /> <br /> <br /> <br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Ok, since that is so, the answer could only be either 0 or 1, since both when squared equal what it orginally was. </div> </div> </blockquote> Unfortunately, as Cristo said, I misread \frac{1}{e^2} as \frac{1}{e^{2x}}. Check what he wrote.
  • · Replies 24 ·
  • · Replies 18 ·
