Express the following in the form of a Complex Number
The discussion focuses on expressing the equation x = cos(wt + ∏/4) - sin(wt) in the form of a complex number. The user applies Euler's formula, e^iwt = cos(wt) + isin(wt), to rewrite the equation as Re[e^i(wt + ∏/4) + ie^iwt]. The complex amplitude is calculated to be √2.414, and the complex angle is determined to be 35.26 degrees or 0.6155 radians. The final expression derived is x = Re[√2.414 e^i(0.6155 + wt)], confirming the correct transformation into complex form.
  • Understanding of Euler's formula e^iθ = cos(θ) + isin(θ)
  • Knowledge of complex numbers and their representation in polar coordinates
  • Familiarity with trigonometric identities and transformations
  • Basic skills in manipulating complex amplitudes and angles
  • Learn about complex number representation in polar coordinates
  • Study the application of Euler's formula in wave mechanics
  • Explore the concept of complex amplitude in physics
  • Investigate the relationship between phase shifts and complex numbers
Students in physics or engineering, particularly those studying wave mechanics, complex numbers, and their applications in oscillatory systems.
Minhq604
For my waves class, I have to do this problem. I've previously completed a question like this except there was no phase constant (∏/4) in that question.
Express the following in the form x = Re [Ae^i\alphae^iwt
x=cos(wt + ∏/4) - sin(wt)
euler's formula e^iwt = cos(wt) + isin(wt)
complex amplitude = √A2+B2
complex angle = tan \alpha = y/x
I know that cos(wt + ∏/4) = Re [e^i(wt + ∏/4)] and -sin(wt) = Re [ie^iwt]
combining these two, i have Re [e^i(wt + ∏/4) + ie^iwt] which, after factoring, becomes
Re [e^iwt (e^i∏/4 + i)]
My problem is, what do i do with the e^i∏/4 to get the complex amplitude and complex angle? In my previous problem without the ∏/4 shift, i was able to plot in Cartesian coordinates I am vs Re and successfully convert to polar coordinates. Help?
##e^{i \pi/4}## is a complex number. So is ##e^{i \pi/4} + i##. Find it, then represent it as ## A e^{i\alpha}##.
How about changing your x into x = Acos(x + ψ)? Just high school trig.
so i made the e^i\pi/4 into cos(\pi/4)+sin(\pi/4) by using eulers formula. Now i calculated the complex amplitude to be √2.414. and the complex angle to be 35.26 degrees or 0.6155 rad. The answer i get is x = Re [√2.414 e^i0.6155t e^iwt ] is this correct?
This is the complex amplitude of what?
