Expressing a surface in cartesian coordinates from spherical
To convert the surface defined by θ = π/4 from spherical to Cartesian coordinates, the relationship between the coordinates must be established using the equations x = r sin(θ) cos(Ø), y = r sin(θ) sin(Ø), and z = r cos(θ). Given θ = π/4, the equation simplifies to z = r cos(π/4), which leads to z = (1/√2)r. The value of r can vary from 0 to infinity, while Ø can range from 0 to 2π. It's crucial to ensure that the notation used for the spherical coordinates is consistent, as any discrepancies can affect the calculations. The final expression represents a plane in three-dimensional space where z is proportional to the radial distance r.
acedeno
The following equation describes a surface in spherical coordinates. θ =pi/4
Write the equation in the cartesian coordinates?
that is, (r,θ,Ø) to (x,y,z)
x=rsinθcosØ
y=rsinθsinØ
z=rcosθ
r=sqrt(x^2+y^2+z^2)
θ=cos^-1(z/r)
Ø=tan^-1(y/x)
I'm pretty stumped. The only start I can get is that if θ=pi/4, this means that r and phi have to work around this. Allowing r to be from 0 to infinity. I'm not really sure what happens to phi. I'm thinking that it can be anywhere from 0 to 2pi.
If your surface is simply defined as
\theta = \pi/4
then all you need to do is solve your conversion factor from theta of
\theta = cos^{-1}(\frac{z}{r}) = cos^{-1}(\frac{z}{\sqrt{x^{2}+y^{2}+z^{2}}})
Since your value of theta is a constant, you just have
\frac{z}{\sqrt{x^{2}+y^{2}+z^{2}}} = cos(\frac{\pi}{4})
Although you may want to make sure you have your notation correct. Generally I've seen
z = r cos\phi, x = r cos\theta sin\phi, y = r sin\theta sin\phi
and if you did in fact get your notation mixed up (which it's possible that you did or didn't, but it's worth checking) that changes the nature of your calculations.
