Expression for the internal potential
The discussion revolves around deriving an expression for the internal potential in an isolated n-type silicon sample, which has a varying electron concentration. The internal electric field is established due to the space charge region, counteracting the diffusion process that generates more space charge. Participants suggest clarifying the setup and consider the linear charge density to understand the field gradient. A resource link is provided to assist with the derivation. The conversation emphasizes the importance of clear communication in technical inquiries.
Ana.B
Any one has any ideas where can i find an expression for the internal potential that results in an isolated silicon sample...
i know why this internal electric field is set up due to the space charge region... having the diffusion process that tends to generate more space change and the electric field itself generated by the space chare that tends to counteract the diffusion...
thnks
Potential with respect to what?
Hi:)
basically when a silicon sample is isolated, there will be an internal electric field set up due to the space charge region ...now i need to derive an expression for this internal potential field... I am not sure what i should consider
Your question is unclear.
Try describing your setup in more detail.
Excuse me about that its my first time using this sort of help... basically i have the following...
first i have an n type silicon , and electrons are supplied to it to keep the concentration constant. and then the current density is found... by the data given are 2um long varies linearly from 10^17 at one end to 6 X 10^16. un(mobility) being 1000...
now this silicon is isolated and explained that it will have an internal electric field and i need to figure out an expression for the internal potential and then i have to calculate it... i don t know what i should consider... hopefully i made myself clearer.thanks
Better, but making oneself clear is a skill in its own right. :smile:
Does your question involve something like this?
http://www.springerlink.com/content/n03vj82865q27173/
If you are saying that the charge density is linear then I would imagine that that the field gradient would be linear as well, but I really have no idea if this applies to your question.
Thanks for your help:) You actually did help me:) I guess you have a great skill :)
Regards,
Ana
  • · Replies 21 ·
