Extrema on high degree polynomial
The discussion focuses on finding extrema, points of inflection, asymptotes, and symmetry for the function f(x) = (x^5 - 10x^3 + 9x) / (x^4 - 16). The first derivative, calculated using the Quotient Rule, is f'(x) = (5x^8 - 4x^7 + 10x^6 - 107x^4 + 480x^2 - 144) / (x^4 - 16)^2. Critical numbers are identified as points where f' equals zero or is undefined, with x = 2 and x = -2 being points of discontinuity. The discussion emphasizes the need to factor the numerator of f' to find zeroes and suggests using the Rational Root Theorem for this purpose.
  • Understanding of calculus concepts such as derivatives and critical points.
  • Familiarity with the Quotient Rule for differentiation.
  • Knowledge of polynomial functions and their properties.
  • Ability to apply the Rational Root Theorem for finding roots of polynomials.
  • Learn how to apply the Quotient Rule in more complex scenarios.
  • Study methods for factoring polynomials, particularly higher-degree polynomials.
  • Explore graphical analysis techniques to identify extrema and points of inflection.
  • Investigate the Rational Root Theorem in detail to enhance polynomial root-finding skills.
Students and educators in calculus, particularly those focused on polynomial functions and their derivatives, as well as anyone seeking to improve their skills in finding extrema and analyzing function behavior.
chickenwing07
Find any extrema, points of inflection, asymptotes, and symmetry for function.
f(x) = (x^5-10x^3+9x) / ( x^4 - 16)
Extrema: I took the first derivative by using the Quotient Rule, and got
(x^8 + 10x^6 - 107x^4 + 480x^2 - 144) / ( x^4 - 16)^2
I know that to find an extrema, I need to determine the critical numbers. Which are when f ' is equal to 0 or is undefined. I determined that "2" makes f ' undefined, but it also is not defined in the original function, f(x), so that is not a critical number. But I cannot for the life of me figure out how to factor the numerator when set to 0.
I tried to graph f ' , and it seems like x = 0 is a critical number, but when i plug it into the numerator it gives me -144...I feel like I am missing something, can someone please help me figure out how to determine the critical numbers please? I think I'm having more algebra issues than calculus.
Then there's the possibility that I took the wrong first derivative. If someone could check me on that, I would be thankful.
Your derivative is incorrect. I get
f'(x) = (5x^8 - 4x^7 + 10x^6 - 107x^4 + 480x^2 - 144)/(x^4 - 16)^2
Edit: My mistake. My brain misfired when I added 5 and 3 and got 7. It should be
f'(x) = (x^8 + 10x^6 - 107x^4 + 480x^2 - 144)/(x^4 - 16)^2
f is undefined at x = 2 and x = -2, which you can see by factoring the denominator in f(x).
It might be helpful to sketch a graph of the function first. That way you could get an idea of approximately where the minima and maxima are. The numerator of your function factors easily, making it easy to find the five x-intercepts for the graph of the function. The denominator also factors easily. Since there are no factors in common between the numerator and denominator, there will be four vertical asymptotes.
If you divide the numerator by the denominater, you get x + a proper rational function, which means that there is a slant asymptote (i.e., the graph of the function eventually approaches the graph of y = x).
To find the zeroes of the numerator of f'(x), you'll probably need to use the rational root theorem. In a polynomial anxn + ... + a1x + a0 = 0, any rational roots p/q are such that p divides a0 and q divides an. For your problem, the polynomial you're trying to factor is 5x^8 - 4x^7 + 10x^6 - 107x^4 + 480x^2 - 144, so p has to divide 144 and q has to divide 5. Fortunutely 5 has factors only of +/-1 and +/-5. If you drew a graph of y = f(x), there will be many potential candidates that you won't need to check.
[/quote]
It looks like you took the first derivative correctly. Try plotting out f and f' to identify the extrema, points of inflection, etc.
For what it's worth, I got the same first derivative as you did.
y'=[(x^4-16)(5x^4-30x^2+9) - (x^5-10x^3+9x)(4x^3)]/(x^4-16)^2
=(5x^8-30x^6-71x^4+480x^2-144-4x^8+40x^6-36x^4)/(x^4-16)^2
=(x^8+10x^6-107x^4+480x^2-144)/(x^4-16)^2
phyzguy and JOhnJDC, you are correct.
