sophiecentaur
Homework Helper
- 30,462
- 7,493
Yes. In that machine, it looks liked the pressure is high - or it may be that the total force (Pressure X area) is high - much higher than a home machine. I bet the mix is pretty critical to get the shape right. The offset hole is just visible at 39s.Baluncore said:a pressure gradient is established, that forms the curve.
Glorious old piece of film though.
Thanks for that response. You'd have to be pretty strongly motivated to DIY regularly. It seems much harder work than making bread at home, which I do all the time. It's our sole source of bread except for the occasional sourdough loaf. Sourdough making is more a way of life than just a recipe.JT Smith said:I've made pasta with the roller type machines before. It's a lot of work. Nowadays locally made fresh pasta is readily available in markets. It's a little bit pricey compared to dried pasta but not bad when you figure in the labor costs of doing it yourself. Frankly I don't think fresh pasta is better; it's just different. I buy it once in a while just for the change. There IS a difference in the quality between dried pastas though. I find it's worth it spend extra as even the more expensive pastas are still pretty cheap.
BTW, I tried the machine today. It was easy to operate and produced nice little noodles but the dough collected in every nook and cranny. Cleaning looked to be quite the chore. Then I discovered that the central pathway wouldn't come out of the housing which would make cleaning a lot harder. I tried to get it free, even succumbing to using WD-40 on where I assumed it had fused with the shaft. No luck. Maybe it will come loose with some soaking time. I'm not going to be making pasta with this thing anyway. Probably it will be in next week's trash.
