F(avg) and Fmax during collision
  • Thread starter Thread starter keltix
    Collision
The discussion focuses on calculating the maximum force (Fmax) experienced by a 60 g Superball during its collision with a wall, given its initial velocity of 32 m/s. The average force (Favg) was calculated to be 657 N, but participants debated how to derive Fmax. The final consensus determined that Fmax equals 160 N, achieved through geometric analysis of the force-time graph, specifically by calculating the area under the curve and relating it to impulse.
  • Understanding of impulse and momentum principles
  • Familiarity with force-time graphs
  • Basic knowledge of geometry related to area calculations
  • Ability to perform integration for average force calculations
  • Study the relationship between impulse and momentum in physics
  • Learn how to analyze force-time graphs for collision scenarios
  • Explore geometric methods for calculating areas under curves
  • Investigate advanced applications of Fmax in real-world collision analysis
Physics students, educators, and anyone interested in understanding collision dynamics and force calculations in mechanics.
keltix
Superball Hits Wall Figure 7-24 shows an approximate plot of force magnitude versus time during the collision of a 60 g Superball with a wall. The initial velocity of the ball is 32 m/s perpendicular to the wall. It rebounds directly back with approximately the same speed, also perpendicular to the wall. What is Fmax, the maximum magnitude of the force on the ball during the collision?
http://i234.photobucket.com/albums/ee9/locowise/10_32.gif"
change in p= p(final)-p(initial)=Favg*change in time
F(avg)= 657
But no idea how to find Fmax!
F(avg)= 657
Just curious how did you calculate F (avg)?
change in momentum=f(avg)*change in time
.058kg(-34-34)=(avg)*change in time
-3.944=f(avg)*.006s
im not sure about the negatives
-3.944=f(avg)*.006s
Ok, I'd got 640N but that's because we both took different masses? Now all I'm going to ask is this, if you were to get the average Force from the graph only (i.e let's pretend you could only work it out from the graph, and the F values were given) how would you do it?
sum all the forces and divide by the number of forces (integral?)
Yep, but that is unnecessary here? What are you doing when you sum all those forces and divide by the number of forces?
taking the average
keltix said:
taking the average
Lol, yeah :smile: should have said (other than taking the average)
What are you doing when you're intergrating something?
taking the area under curve
Correct!
When you're taking the average of any function what you are essentially doing is finding a rectangle of equal area that represents the area under the curve of that function.
The "height" of this rectangle will give the average value.. does this help?
ok but how do i find the area if i don't have the height
You have the area (the integral) and you have one of the sides (the time duration of the impulse). The F_avg is easily found with this info.
Im not trying to find the Favg
The area of you're rectangle is equal to some height on the y-axis multiplied by the some length l on the x-axis.
If I told you the length of your rectangle was 6 (seconds).
Now look at your graph what is the height equal to?
What I'm trying to get you to realize here is that the area, can be redrawn as a single rectangle, the value of the height of this rectangle will give you the average.
So what if you were to convert the region under curve into a rectangle of equal area?
Hopefully you would notice that the height of this rectangle is exactly half the height of highest point of the curve in your given question.
Just mess around with at bit and you should see it.
Now, this means that Fmax is equal to twice the height of a rectangle of equal area .. ..
Sorry, I read the wrong post. It's simple geometry to find Fmax... Since you know what the impulse is (Favg * dt) all you have to do is break down the area under the Fmax curve into expressions involving Fmax. The left and right triangles are obviously 1/3dt * 1/2 * Fmax and the central block is a rectangle with base 1/3dt and height Fmax. Just solve for Fmax...
Ans=160N
  • · Replies 22 ·
20K
