Fabricating With Bearing Question
  • Thread starter Thread starter average guy
    Bearing
This discussion focuses on the fabrication of hubs using Timken-type bearings, specifically addressing the terminology related to bearing components. The inner ring and roller assembly is referred to as the "cone," while the outer ring is known as the "cup." The user plans to machine a shaft for a bearing to fit securely at each end of a 2-inch diameter aluminum tube, which requires sufficient wall thickness to accommodate the bearing cup.
  • Understanding of Timken-type bearings
  • Knowledge of machining processes for aluminum
  • Familiarity with bearing terminology, specifically "cone" and "cup"
  • Basic skills in designing and fabricating mechanical components
  • Research suitable aluminum alloys for machining, such as 6061 or 7075
  • Learn about the machining techniques for creating bearing seats
  • Explore the specifications and tolerances for Timken-type bearings
  • Investigate the design considerations for one-off hub fabrication
This discussion is beneficial for mechanical engineers, machinists, and hobbyists involved in custom fabrication projects, particularly those working with bearings and aluminum components.
average guy
have to get up to speed on bearings
building one off hubs
using timken type bearings
what's the correct name for the
bore the backside of bearing goes into?
same question for shoulder that keeps
bearing from going into tube?
i did some research on this at wikipedia under 'Tapered Roller Bearings'
'The non-separable inner ring and roller assembly is called the cone, and the outer ring is called the cup'
plan is to machine shaft for a bearing to fit in each end
and stay there
what is a good all round aluminum to use for this?
about 2" diameter tubing with enough wall to machine
to hold bearing cup
  • · Replies 16 ·
