There are other methods for factoring quadratics...but sometimes trial and error is the fastest way.
In your particular problem, what we can try to do is multiply the leading coefficient (3) by the constant term on the end (6) giving 18.
Using this method, you say to yourself "I have no way of knowing which factors will work, so I'll just throw them all in together and then later, get rid of the extras..."
[tex]3x^2-11x+6[/tex]
3x6=18
I need factors of 18 that ADD to give me 11 (you have to understand what the plus and minus signs and their location means in the original equation)
so we list them off:
2 9
3 6 (obvious)
I like 2 and 9...2+9=11
since we included ALL factors, the method says that you write this (fully aware that you are NOT done:)
(3x-9)(3x-2)
Clearly, if you FOIL that, It doesn't work, but since we started out not knowing what factors would work, we have extra factors in there, so we need to get rid of the unwanted ones. The way this is done is to look at each binomial factor separately and see if there is something that can be divided out and thrown away:
we have:
(3x-2) and (3x-9)
so we look at (3x-2). There is no common factor in the terms there, so we leave it.
Then we have (3x-9). We can divide both terms by 3...throw the extra 3 away.
You are left with (x-3).
So your final answer is the first binomial (3x-2) and the second one with the extra 3 thrown out, (x-3).
All of that being said, MOST of the time, trial and error works. There is also another method that involves rewriting the original equation as:
[tex]3x^2-2x-9x+6[/tex] and then using factoring by grouping to arrive at the solution.
you get:
[tex]x(3x-2)-3(3x-2)[/tex]
and then:
(x-3)(3x-2)
I prefer the trial and error method 95% of the time.
All of these methods require lots of practice and still take up paper and time...and if your leading coefficient is 30 and your constant is 11, you have to multiply 30 x 11 and then list off all of those factors...can be way worse than trial and error.
best of luck
CC
