Failure of a system of components logically arranged in series and parallel
The discussion focuses on the failure analysis of a system of valves arranged in series and parallel configurations, specifically valves V1, V2, V3, V4, and V5. The performance assessment reveals that the useful life of the system lasts up to 5 years, with failure modeled using an exponential distribution function. The calculated probability of a loss of flow from the manifold within 3 years is confirmed to be 0.08643, based on the parameters λ1, λ2, λ3 at 0.05, λ4 at 0.267, and λ5 at 0.189, all expressed in years−1.
  • Understanding of exponential distribution functions
  • Knowledge of reliability engineering concepts
  • Familiarity with probability calculations in systems
  • Basic skills in mathematical modeling of component failures
  • Study the application of exponential distribution in reliability analysis
  • Learn about series and parallel system configurations in engineering
  • Explore advanced reliability modeling techniques
  • Investigate the impact of component failure rates on system performance
Engineers, reliability analysts, and students in fields related to systems engineering and reliability analysis will benefit from this discussion, particularly those focused on the performance assessment of mechanical systems.
abba02
[SOLVED] failure of a system of components logically arranged in series and parallel
The performance of the valves in (V1 OR V2 OR V3) AND V4 AND V5 has been assessed in more detail under conditions
closer to those experienced in-service and the distribution functions of the random time
to failure have been quantified. The useful life period, prior to wear-out, occurs from
installtion to 5years. During this period, all of the distribution functions are modeled
using an exponential distribution function of the form:
FT (t) = 1 − exp[−_λit] where i=1,2,3,4,5
If _λ1 = λ_2 = _λ3 = 0.05; λ_4 = 0.267; λ_5 = 0.189 (all in years−1), calculate the probability
of a loss of flow from the manifold sometime in the period (0,3)years.
ANSWER[P[F]=0.08643]
Assummed that V1,V2 AND V3 ARE IN SERIES AND ARE IN PARALLEL WITH V4 AND V5
= 1- exp [-λ1+λ2+λ3+λ4+λ5*3]
Have tried to substitute .05,.267 and .189 for lambada, *3 for t in the given equation but my answer is still very different from the given answer of 0.08643[/QUOTE]
The attempt at a solution:
V1,V2 AND V3 ARE IN SERIES AND SS1 ARE IN PARALLEL TO V4 AND V5
(PV1 OR PV2 OR PV3) AND PV4 AND PV5
For PSS FT (t) =1- exp [-λ1+λ2+λ3*3] where t=3 = .36237
For PV4, FT (t) =1- exp [-λ4*3]=.55112
For PV5,FT (t) =1- exp [-λ5*3]= .43278
Therefore the probability of loss of flow from the manifold at time 3 years is
PSS1 AND PV4 AND PV5= .36237*.55112*.43278= .08643
