MHB False Positive Rate of 1:1.5M Sampling Process
  • Thread starter Thread starter karamand
    Positive Rate
The discussion centers on the false positive rate of a sampling process where items are classified as type A or B, with a false positive rate of 1 in 1.5 million. When a sample of 1 million yields one classification as type A, the probability of that classification being a false positive is approximately 0.000067. The sample size does not affect this probability, as it remains constant regardless of the number of observations. The conversation highlights the relevance of Bayes' Theorem for more complex scenarios, although it is not necessary in this case due to the known false positive rate. Overall, the key takeaway is that the probability of a false positive remains at 1 in 1.5 million for each individual 'hit'.
karamand
I have a sampling process of a very large population in which all items are of type A or type B. I have an analysis of the sampled objects which classifies type A and gives the wrong identification (a false positive) 1 in 1.5 million times.
I take a sample of 1 million and find 1 'hit' i.e classified as type A. What is the probability that it is a false positive?
Mathematics news on Phys.org
Hi philpq! Welcome to MHB! :)
Without more information, any 'hit' of type A has a probability of $\frac{1}{1.5\cdot 10^6} \approx 6.7 \cdot 10^{-5}$ of being a false positive.
We will still know basically nothing about the other 999999 observations without more information.
Thanks for your help. I suppose the answer is obvious when I think about it. The sample size is irrelevant. The probability of anyone 'hit' being a false positive is 1 in 1.5 million as stated :)
Usually questions about false positives use Bayes' Theorem and for that you need a lot more information.
$$P(+|\text{ (actually negative)})=\frac{P(\text{(actually negative)}|+) \cdot P(+)}{P(\text{actually negative})}$$
In the above, $+$ means "reads positive". However, you already have this probability so the above isn't necessary to calculate. I'm just pointing out that these topics are very often related. Here is an example "false positive" question you can read on Wikipedia.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
