Faraday's Law: Why do external magnetic fields not affect current in a loop?
  • Thread starter Thread starter pmennen
    Faraday's law Law
The discussion revolves around Faraday's Law and its implications regarding the effects of external magnetic fields on induced current in a loop. Participants explore the relationship between changing magnetic fields and induced electromotive force (emf), questioning how external fields influence the current within the loop.
  • Participants discuss the direction of induced current and its relation to Lenz's Law, questioning how external magnetic fields interact with the loop. There is an exploration of the concept of magnetic field lines and their relevance to induced emf, with some participants expressing confusion over the effects of fields both inside and outside the loop.
The discussion is active, with participants providing insights into Faraday's Law and its application. Some have offered clarifications regarding the nature of magnetic fields and their influence on induced current, while others are still grappling with the implications of external fields and the specifics of the problem setup.
There is mention of varying interpretations of the magnetic field's influence, particularly regarding uniform fields and their effects on the loop. Participants also reference the need for a deeper understanding of the principles involved, suggesting that some foundational concepts may require further exploration.
pmennen
The answer to this question (attached gif) is supposed to be "E".
I can get bL^2/R if I just compute the flux and differentiate to
compute the induced voltage and current, but how does one
figure out that it goes counter-clockwise. Also I'm at a loss to
explain why whatever effects the field has on the left side of the
loop wouldn't cancel out the effects on the right side of the loop.
(i.e. I was also tempted to answer "0"). Thanks in advance for any
insight. (Sorry if this is a double post, the 1st one seems lost?)
~Paul
The induced current produces a magnetic field in addition to the external field "B". This induced field will be opposite to the change in B (not necessarily opposite to B itself). What direction must the current flow to produce a field in the opposite direction of [tex]\frac{dB}{dt}[/tex] ?
You can look up Lenz's Law in your textbook for more discussion of this.
Lenz's law
Thanks for your reply.
Ok, yes I'm aware of Lenz's law and I can understand which direction the
induced current goes when you push a magnet into a loop of wire. But this
situation is a bit different. So when the magnetic field in this problem decreases,
it decreases both inside and outside of the loop. So the counter clockwise direction
indeed counters the change inside the loop, but it goes in the same direction of the
change outside the loop. So it didn't seem to me that Lenz's law tells me the
answer to this problem.
What do you mean by inside and outside the loop? The magnetic field runs through the loop (at least through an open surface attached to the loop). If it helps, picture the magnetic field coming out of the end of a bar magnet.
I don't understand your question. The problem shows a "uniform" magnetic field shown by the dots on the page. Note that there are dots both inside the loop of wire and outside, and they are uniformly spaced. That is not the same as the field coming out of a bar magnet that is being pushed thru the loop. In that case the field would be string near the end of the magnet and would fall off in strength farther away from the magnet.
~Paul
Faraday's law relates induced emf in a loop to the change in electric flux across an open surface attached to that loop. Magnetic field lines that do not cross that open surface--in other words ones that do not cross the loop--do not affect induced emf. Thus, they do not affect the current. I understand that your question is why magnetic field lines outside the loop do not seem to affect the current. Maybe there is a more sophisticated answer in advanced physics that I don't know that someone else can fill you in on, but empirical evidence supports Faraday's law the way it is.
I wasn't really trying to question Faraday's law at this stage of my limited understanding. My problem was I hadn't read it carefully enough to understand what it was saying. Your answer however has cleared it up for me nicely. Many thanks!
~Paul
This can generally be shown with Gauss' Law (or Divergence Theorem), or in this 2-D case, with Green's Theorem, which implies that what happens along a closed contour is dependent on what happens in the area within the contour. If you are comfortable with vector calculus, take a look at the wikipedia entry, and it should at least become clear in a mathematical sense, if not intuitively.
