NeoDevin said:
I'm trying to find the lowest eigenvalue (for now, eventually I may need other eigenvalues.). I figured that diagonalizing was the easiest way to go.
Diagonalizing will give you all the eigenvalues. That is not a practical option for problems matrices bigger than about 500x500. For anything bigger than that, it will run very slowly (run time proportional to matrix size cubed) and/or the numerical conditioning will be too poor to get any answers at all.
That rules out QR/QL type methods (except on a 300x300 size problem) because they always calculate all the eigenvalues.
The best general-purpose algorithm for calculating a few eigenpairs of a large matrix is the Lanczos method. That needs a matrix factorization and equation solving algorithm for your sparse matrices.
A simpler alternative, if you just want the lowest eigenpair and the low eigenvalues are well separated, is the Inverse Power Iteration method.
Unless you want to learn a lot about linear algebra computations and have a couple of years to spare, don't try to code your own versions of a sparse solver or the Lanczos method from scratch.
http://www.netlib.org/linalg/spooles/spooles.2.2.html is a reputable place to start.
To give you an idea of what is feasible, I once calculated the lowest 3000 eigenpairs of a 300,000 x 300,000 sparse system successfully - though it took about 3 months to get the problem formulated properly, and the run time on a 4-processor Silicon Graphics box was about 3 days.
At the other end of the size range, run time for a 300x300 size problem would be of the order of < 1 sec.
