Favorite infinite products and applications
20 replies · 3K views · last reply
Insights Author
I've always had a fascination with infinite products. I like them, I do. To stimulate our ensuing conversation, I here post Knopp's two-way series-to-product (and vice-versa) "doorway" out of his book, Theory and Applications of Infinite Series pg. 226:
Knopp said:
1. If ##\prod_{n=1}^{\infty}(1+a_n)## is given, then this product, if we write
$$\prod_{\nu =1}^{n}(1+a_{\nu})=\mathfrak{p}_n \, ,$$
represents essentially the sequence ##(\mathfrak{p}_n )##. This sequence, on the other hand, is represented by the series
$$\mathfrak{p}_1 + ( \mathfrak{p}_2 - \mathfrak{p}_1) + ( \mathfrak{p}_3 - \mathfrak{p}_2) + \cdots = \mathfrak{p}_1+\sum_{n=2}^{\infty}(1+a_1)\cdots (1+a_{n-1})\cdot a_n$$
... [omitted text]
2. If conversely the series ##\sum_{n=1}^{\infty}a_n## is given, then it represents the sequence for which ##s_n=\sum_{\nu = 1}^{n}a_{\nu}##. This is also what is meant by the product
$$s_1\cdot\tfrac{s_2}{s_1}\cdot\tfrac{s_3}{s_2}\cdots = s_1\cdot \prod_{n=2}^{\infty}\tfrac{s_n}{s_{n-1}} = a_1\cdot \prod_{n=2}^{\infty}\left( 1+\tfrac{a_n}{a_1+a_2+\cdots +a_{n-1}}\right) \, ,$$
--provided it has meaning at all. ...
Maybe that'll break the ice... please post your favorite infinite product (or application thereof).
\sum_{n\in \mathbb{N}} \dfrac{1}{n^s} = \prod_{p\in \mathbb{P}}\dfrac{1}{1-p^{-s}}
Consider a field ##\mathbb{F}## with ##q < \infty## elements. Consider the set of all monic polynomials in ##\mathbb{F}[X]## by ##\mathcal{M}##. Then
$$\sum_{N \in \mathcal{M}} z^{\deg(N)} = \prod_{P \in \mathcal{M}\setminus \{1\}: P \mathrm{\ irreducible}} \frac{1}{1-z^{\deg(P)}}$$ for ##0 \leq z < 1/q##.
Denote the amount of all irreducible polynomials in ##\mathcal{M}## of degree ##m## by ##i_m##. Then the above formula implies
$$q^k = \sum_{m | k} mi_m$$
and as a corollary of that ##i_m > 0## for all ##m##, which is highly non-trivial.
I really like this as this uses analysis to obtain algebraic results.
My formula has the same structure as yours! Moreover, both products range over irreducible elements. There must be some generalisation!
Maybe by taking the projective limit of ##\mathbb{F}_p## over all primes, possibly the algebraic closures of ##\mathbb{F}_p##. There is one crucial difference: Whereas Euler / Dirichlet have the variable in the exponent, your formula has the variable in the base and an invariant in the exponent. Hower, I would bet there is a connection. Do you know a formulation which uses characters instead of degrees?
What do you mean with characters?
Group characters. I was wondering if the formula can be phrased as sum over functions ##\chi: \mathbb{F}_q \longrightarrow \mathbb{C}^*##, but this was just an idea, not that I had a solution in mind.
No, unfortunately I'm not aware of something like that. Maybe someone with expertise in analytic number theory can help here.
Does anybody know the geometric significance of infinite products? I get how multiplication of two complex numbers works graphically, polar form does this simply enough the modulus of the product is the product of the moduli and the argument of the product is the sum of the arguments but how does one extend this to infinitely many multiplications? Could we just start off with the partial product? Then apply some sort of limiting procedure? I've never seen this done in texts before, but seems like something they would have done along time ago
An infinite product is usually defined as
$$\prod_{n=0}^\infty a_n = \lim_{k \to \infty} \prod_{n=0}^k a_k$$
but some authors (e.g. Apostol) make conventions like such a product does not converge if it contains infinitely many zeros etc, though the partial products are all ##0## then.
Yes convergence of ##\prod_{k=1}^{\infty}a_n## will require that each term is non-zero and that ## | a_n|\rightarrow 1## as ##n\rightarrow \infty## and iirc (correct me if I'm wrong, I may be) ##\text{arg}\, a_n \rightarrow 2k\pi\text{ for some } k\in\mathbb{Z}^+##. These are necessary but not sufficient.
Edit: this is equivalent to requiring an infinite series general term go to zero for convergence and since the arg of the partial product is the partial sum of the arg's the general term must go to zero (up to multiples of ##2\pi##.
There is no reason why infinite products with infinite many factors unequal one shouldn't be considered, e.g. Euler's formula for the Riemannian zeta function. Or the distinction between direct sums and direct products in algebra.
I find the above remark about zeroes in a product more than strange, infinite or not.
iirc Knopp speaks of a product diverging to zero, but this is just convention. And for Euler's product for the zeta function I think you misread what I wrote because ##\left| \tfrac{1}{1-p^{-s}}\right| \rightarrow 1## as ##p\rightarrow \infty## through the primes for all s that the product converges for, no?
Edit: I re-read Knopp, he defines that no terms ##a_n## should vanish for all ##n>m## for some fixed m in order to converge and that the the partial product beginning immediately beyond this point, ##\prod_{\nu =m+1}^{n}a_{\nu}## tend as n increases to a definite limit.∏ν=m+1naν
I'm not saying they shouldn't be considered. I'm just saying that some authors do not consider such products as "converging". I do not have enough expertise in the matter to say this is justified or not.
benorin said:
Speaking of the Euler product, how would the product over primes be analytically continued globally?
I don't understand the question. The primes aren't the variables, the exponent is.
Obviously it does converge and is analytical. It is just another way of writing it. For a proof the Dirichlet series is probably better suited. Wikipedia mentions Knopp and Hasse (ca. 1930) for a proof of holomorphy.
benorin said:
The Euler product only converges for ##\Re s >1##.
I have't looked into the details. Wikipedia says:
One obtains a series identity first published by Konrad Knopp, which holds on ##{\displaystyle \mathbb{C} \setminus \{1+2\pi \mathrm{i} m/\log 2\mid m\in \mathbb{Z} \}}##
$$\zeta (s)={\frac {1}{1-2^{1-s}}}\sum _{n=0}^{\infty }{\frac {1}{2^{n+1}}}\sum _{k=0}^{n}(-1)^{k}\ {n \choose k}\ {\frac {1}{(k+1)^{s}}}$$
This has been proven by Helmut Hasse in 1930. There are therefore no further gaps or poles during the continuation. This finally results in holomorphy on ##{\displaystyle \mathbb{C} \setminus \{1 \}}.##
