Fermat's Last Theorem related question
  • Thread starter Thread starter Ninty64
    Theorem
The discussion focuses on proving that the equation x^n + y^n = z^n has a nontrivial integer solution if and only if the equation 1/x^n + 1/y^n = 1/z^n has a nontrivial integer solution. A successful proof in one direction is presented, demonstrating that a solution to the second equation implies a solution to the first. However, the reverse direction remains unresolved, with challenges in applying the same logic backward without additional assumptions. Suggestions include considering the symmetry of the equations to facilitate the proof. The conversation highlights the complexities involved in proving both directions of the equivalence.
Ninty64
Show that x^{n}+y^{n}=z^{n} has a nontrivial solution if and only if the equation \frac{1}{x^{n}}+\frac{1}{y^{n}}=\frac{1}{z^{n}} has a nontrivial solution.
By nontrivial solutions, it is implied that they are integer solutions.
I was able to solve in one direction
Given an integer solution to \frac{1}{x^{n}}+\frac{1}{y^{n}}=\frac{1}{z^{n}}
Then it follows that:
\frac{x^{n}+y^{n}}{x^{n}y^{n}}=\frac{1}{z^{n}}
x^{n}y^{n}=z^{n}x^{n}+z^{n}y^{n}
(xy)^{n}=(zx)^{n}+(zy)^{n}
Therefore, since the set of integers is closed under multiplication, then x^{n}+y^{n}=z^{n} has a nontrivial solution.
However, I can't seem to prove the other direction. Working the above proof backwards doesn't work unless I assume that d = gcd(x,y) and somehow prove that z = xy.
Applying exactly the same method in the reverse direction appears to work.
I might note that ##\frac{1}{\frac{1}{x^n}}+\frac{1}{\frac{1}{y^n}}=\frac{1}{\frac{1}{z^n}}## is identical to writing ##x^n+y^n=z^n##. Then you can refer back to your earlier proof.
alternatively, since the formula you start with is symmetric, try doing something symmetric to it :wink:
  • · Replies 21 ·
