Feynmann diagrams, bhabha scattering
  • Level: Graduate
  • Thread starter Thread starter physics_fun
    Diagrams Scattering
15 replies · 5K views
physics_fun
There is nowone who can help me on the homework forum, so i'll try it here...
physics_fun said:
I'll try a little LATEX to make the problem more clear:
[tex] p_{1} + p_{2} = p_{3} + p_{4}[/tex]
These are four vectors of the in- and going momenta
You take the frame where the threemomentum [tex]p_{2}=0[/tex]
Questions:
1) Why does then defining threemomentum [tex]p_{4}=p_{3}[/tex] imply that [tex]p_{4}=p_{3}=0[/tex]? (threemomenta!)
And why does defining [tex]p_{3}*p_{4}=0[/tex] (three vectors) imply that [tex]p_{3}=0 or p_{4}=0[/tex]?
3. The Attempt at a Solution
I tried: 4-vectors: [tex] p_{1} + p_{2} = p_{3} + p_{4}[/tex]
square this: [tex](p_{1})^(2) + (p_{2})^(2) + 2p_{1}p_{2}= (p_{3})^(2) + (p_{4})^(2) + 2p_{3}p_{4}<br /> //<br /> (p_{1})^(2)=(p_{3})^(2)=m (electron mass)//<br /> (p_{2})^(2)=(p_{4})^(2)=M (positron mass)[/tex]
So: [tex]p_{1}p_{2}=p_{3}*p_{4}[/tex]
The lab frame condition gives:
[tex]p_{1}^{0}p_{2}^{0}=p_{3}^{0}p_{4}^{0}-p_{3}*p_{4}(three-vectors)[/tex]
But what are the next steps?
Thanks for your reply!
I still don't get it exactly
First Question:
If p3=p4, then p3-p4=0 and the moment of q=p1+p2=p3+p4, I don't get why it should be 0...
Second Question:
The '*' is the innerproduct (inproduct), so I don't know if then the rest of your reply holds?
First Question: (edited for the annihilation-creation diagram)
The answer follows from the on-shell condition.
E1+m = E3+E4, p1 = p3+p4
This means that E1 and p1 can only be on-shell if p3=p4=0
Second Question:
General advice: First try to simplify things with the given relations before
starting to take squares and things like that. Then use the on-shell
relations to prove the given restrictions.
I suppose the '*' is the cross product here. The cross product means that
p3 and p4 are in the same direction, thus (p4x,p4y,p4z) = a(p3x,p3y,p3z)
This gives us:
[tex]E_4+E_3\ =\ \sqrt{ a^2p_3^2 + m^2} + E_3[/tex]
Since p2= (m,0,0,0) we have q = (E1+m, p1x, p1y, p1z)
It follows that (p1x,p1y,p1z) = (1-a)(p3x,p3y,p3z)
This gives us:
[tex]E_1 = \sqrt{ (1-a)^2p_3^2 + m^2) }[/tex]
Thus:
[tex]E_3 = m + \sqrt{ (1-a)^2p_3^2 + m^2} - \sqrt{ a^2p_3^2 + m^2) }[/tex]
This means that either [itex]a[/itex] must be 0 and thus p4=0 or p3=0.
There is another solution and that is [itex]a=1[/itex]. In this trivial case p4=p3
and they can be non-zero...Regards, Hans
First Question:
To which of the two diagrams contributing to Bhabha scattering are you
referring to. The electron positron scattering or the annihilation/creation one?
Second Question:
It holds for the x product...:smile: (for the annihilation/creation diagram)Regards, Hans
Annihahilition: p1+p2(incoming momenta)=p3+p4(outgoing momenta)
Scattering: p1-p3=p4-p2 (toch?)
Doesn't it hold for the innerproduct?
OK, The answer then follows from the on-shell condition.
This means that E1 and p1 can only be on-shell if p3=p4=0Regards, Hans
So p3 and p4 are under 90 degrees. It follows that:
[tex]p_{3\bot} = -p_{4\bot}[/tex]
[tex]p_{3\|} + p_{4\|} = q = p_1[/tex]
The latter is the same as
[tex]{p_1 \over |p_1|} \cdot p_3\ +\ {p_1 \over |p_1|} \cdot p_4\ =\ p_1[/tex]
The first left hand term is zero if the second one is at a maximum
and visa versa. For the energy we have:
[tex]E_1+m = E_3+E_4[/tex]
Now, p1 should be on shell so you have to prove that this is only
true in the two cases given above.
Regards, Hans
Ok, I think I'm getting it now:
E1, E2, E3 are the rest-energies, p1, p3, p4 the three vectors (p2 is defined 0)
Hans de Vries said:
You have:
E1 = E3 + E4 - m = 2E3 - m
and
p1 = p3 + p4 = 2p3
now
[tex]E_1^2 = p_1^2 + m^2[/tex]
thus
[tex](2E_3 - m)^2 = (\ 2p_3\ )^2 + m^2[/tex]
It follows that p3=p4=0
Regards, Hans
I'm understanding this one:cool:!
The factor 2 in 2p3 is true because p3 and p4 must be parallel to q and p1
otherwise it would be a variable.Regards, Hans
About the second: is it true that (threevectors:)
if p2=0, p1=p3+p4
so (p1)^2=(p3)^2+(p4)^2+2(p3)(p4)
now (p3)(p4)=0, so (p1)^2=(p3)^2+(p4)^2, and this can only be true if p4=0 or p3=0?
Hans de Vries said:
The complete proof is a bit more involved since the factor 2 in 2p3 is true only if
p3 and p4 are parallel to q but you can replace the 2 in 2p3 with a variable and follow
the same logic.
Regards, Hans
small angle approximation:wink:
no, the 2 is true anyway :smile:, since p3 and p4 must be parallel to q and p1.
(I modified my post)
Regards, Hans.
if p2=0, p1=p3+p4
You've got an expression for p1 now, as well as E1+m = E3+E4.
Next thing is to prove that
is true only in the two given cases.
Regards, Hans
It's completely clear to me now!
Thank you very much for your help!:smile::smile::smile:
