Field extensions and roots of polynomials
The polynomial $$x^5+2x^4-16x^3+6x-10$$ has no roots in the field extension F of Q with [F:Q] = 24. The proof relies on the polynomial being irreducible over Q, which can be established using Eisenstein's criterion with the prime p = 2. Since the polynomial is of degree 5, it follows that [Q(a):Q] = 5. Consequently, [F:Q(a)] cannot be an integer, confirming the absence of roots in F.
  • Understanding of field extensions and their notation, specifically [F:Q].
  • Knowledge of polynomial irreducibility and its implications.
  • Familiarity with Eisenstein's criterion for irreducibility.
  • Basic concepts of algebraic degrees of field extensions.
  • Study Eisenstein's criterion in detail to understand its applications in proving irreducibility.
  • Explore examples of field extensions and their degrees to solidify understanding of [F:Q].
  • Learn about polynomial roots and their relationships with field extensions.
  • Investigate other irreducible polynomials over Q and their implications in field theory.
Mathematicians, algebraists, and students studying field theory and polynomial irreducibility, particularly those interested in advanced algebra concepts.
mathgirl1
Let F be a field extension of Q (the rationals) with [F:Q] = 24. Prove that the polynomial $$x^5+2x^4-16x^3+6x-10$$ has no roots in F.
Proof:
Let $$a$$ be a root of $$x^5+2x^4-16x^3+6x-10$$. Since the polynomial has degree 5 by theorem we know that $$[Q(a):Q]=5$$. If $$a \in F$$ and $$[F:Q]=24$$ then by theorem we have that $$ [F:Q] = [F:Q(a)][Q(a):Q] \implies 24 = [F:Q(a)] 5 $$ which means that $$ [F:Q(a)] $$can not be an integer which would imply that the polynomial has not roots in F.
I think this is pretty accurate but also seems kind of too simple. Can someone please confirm whether this is correct or give advice to proceed correctly?
Thank you!
Hi mathgirl,
It's not true that since the polynomial has degree $5$, then $[\Bbb Q(a):\Bbb Q] = 5$ as a direct consequence. What you've missed in your argument is that the polynonmial is irreducible over $\Bbb Q$. Since the polynomial is irreducible of degree $5$, then $[\Bbb Q(a): \Bbb Q] = 5$. The irreducibility may be proven by applying Eisenstein's criterion for the prime $p = 2$.
Ah ha! Yes! Thank you very much! I knew I was missing something. Much appreciated!
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 16 ·
